01800.0-01
01800.0-01
    STEGO
01800.0-01 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com FILTER FAN FF 018 | 14 - 69 CFM >>Very low noise >>Minimal mounting depth >>Functional design >>Time-saving installation >>UV resistant plastic TECHNICAL DATA Enclosure ventilation using a filter fan and exhaust filter Axial fan, ball bearing service life min. 50,000 h at 77 °F (25 °C) and 65 %RH aluminum fan body, plastic rotor Connection 2 wires w/ cage clamps, AWG 14 (2.5 mm²), length 4” (100 mm) Housing (filter fan and exhaust filter) plastic, UL 94V-0, light grey Hood (filter fan and exhaust filter) plastic, UL 94V-0, light grey; UV light resistant according to UL 746C (f1) Mounting frame with double-sided industrial adhesive for mounting to the outside of enclosure; certain operating circumstances may make the additional use of screws necessary; cut-out template included Filter media rating G4 acc. to DIN EN 779, filtering degree 94% Filter material synthetic fiber with progressive construction, temperature resistant to 212 °F, self-extinguishing class F1; moisture resistant to 100 %RH, reusable - can be cleaned by washing or vacuuming Operating / Storage temperature +14 to +158 °F (-10 to +70 °C ) / -40 to +158 °F (-40 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Protection class / Protection type I (grounded) / IP55 (according to VDE), UL Type 12 Approvals UL File No. E234324 (all), GOST TR (all), VDE (AC 230 V only) Special features > The self-adhesive seal of the mounting frame prevents dust and water from entering the cabinet. > Functional design of the intake and exhaust fan hoods very effectively prevents direct infiltration of falling water and dust. The advantage is that the filter mat does not rapidly become contaminated with dirtand therefore does not need to be exchanged as often. > The air channeling makes the filter fan particularly quiet in operation. > The direction of air flow can easily be switched by reversing the axial fan. > EMC versions and other voltages are available upon request. Part No. Operating voltage Air volume, free blowing 01800.0-00 AC 230 V, 50 Hz¹ 12 cfm (21 m³/h) 01800.0-01 AC 120 V, 60 Hz 14 cfm (24 m³/h) 01801.0-00 AC 230 V, 50 Hz¹ 32 cfm (55 m³/h) 01801.0-01 AC 120 V, 60 Hz 01802.0-00 01802.0-01 Air volume with exhaust filter Current consumption Power consumption Average noise level (DIN EN ISO 4871) Mounting depth Enclosure cut-out Weight (approx.) 9 cfm (16 m³/h) 80 mA 13 W 31 dB (A) 1.8” (45 mm) 3.8 x 3.8” 1.3 lbs. (0.6 kg) 11 cfm (18 m³/h) 160 mA 13 W 31 dB (A) 1.8” (45 mm) 3.8 x 3.8” 1.3 lbs. (0.6 kg) 25 cfm (42 m³/h) 100 mA 15 W 40 dB (A) 2.3” (58 mm) 4.9 x 4.9” 2.2 lbs. (1.0 kg) 37 cfm (63 m³/h) 28 cfm (48 m³/h) 180 mA 15 W 40 dB (A) 2.3” (58 mm) 4.9 x 4.9” 2.2 lbs. (1.0 kg) AC 230 V, 50 Hz¹ 60 cfm (102 m³/h) 40 cfm (68 m³/h) 100 mA 15 W 39 dB (A) 3.4” (86 mm) 6.9 x 6.9” 2.9 lbs. (1.3 kg) AC 120 V, 60 Hz 69 cfm (117 m³/h) 46 cfm (78 m³/h) 180 mA 15 W 39 dB (A) 3.4” (86 mm) 6.9 x 6.9” 2.9 lbs. (1.3 kg) ¹ air volume increases by 15% when operating AC 230 V filter fans at 60 Hz 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Filter fans are used to provide an optimum climate in enclosures. The interior temperature of an enclosure can be reduced by channeling cooler filtered outside air into the enclosure thus expelling heated internal air. The resulting air flow prevents formation of localized heat pockets and protects the electronic components from overheating. The plastic used for the hood of this filter fan series is impact and UV light resistant. These filter fans are intended for indoor use. www.stegousa.com Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com Time-saving assembly and maintenance STEGO's filter fans are easily installed by one person from outside the cabinet. 1.) Make cut-out in the cabinet wall. The cut edge of the cabinet opening should be free of dirt, filings and grease. A template for the enclosure cut-out is included with the filter fan. 2.) Remove protective film from the sealing strips on the mounting frame. Press mounting frame into the cabinet opening. The frame stays permanently in the cabinet. Installation sketch 3.) Electrically connect the axial fan using the cage clamp connectors. Push the unit into the mounting frame. Affix using screws if necessary. To change the filter mat, simply remove the filter hood, insert the new mat and snap the hood back again. No tools are required. Maintenance of the fan can easily be performed without removing the mounting frame (2). TECHNICAL DRAWINGS Size 1 Size 3 Size 2 DRILLING TEMPLATE FOR MOUNTING FRAME EXHAUST FILTER EF 118 Part No. Mounting depth Enclosure cut-out Weight (approx.) Filter mat Protection type 11800.0-00 0.6” (16 mm) 3.8 x 3.8” 0.6 lbs. (0.3 kg) G4 acc. to DIN EN 779, filtering degree 94% IP552 11801.0-00 0.6” (16 mm) 4.9 x 4.9” 0.8 lbs. (0.4 kg) G4 acc. to DIN EN 779, filtering degree 94% IP552 11802.0-00 0.6” (16 mm) 6.9 x 6.9” 1.3 lbs. (0.6 kg) G4 acc. to DIN EN 779, filtering degree 94% IP552 ² according to VDE FILTER MATS FM 086 / FFM 086 Filter mat 3.5 x 3.5” (89 x 89 mm) 4.6 x 4.6” (118 x 118 mm) G4 (1 packing unit = 3 pcs.) Part No. 08600.0-00 Part No. 08601.0-00 6.6 x 6.6” (168 x 168 mm) Part No. 08602.0-00 F5 (1 packing unit = 3 pcs.) Part No. 08603.0-00 Part No. 08604.0-00 Part No. 08605.0-00 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. 4.) Insert the filter mat in the hood. Clip on. Finished.
01800.0-01 价格&库存
很抱歉,暂时无法提供与“01800.0-01”相匹配的价格&库存,您可以联系我们找货
