90TECHNICAL
90
LIGHTING
DATASHEET
LAMP
LED 025
>>Wide voltage range
>>Integrated power unit
>>Long-lived and maintenance-free
by LED technology
LED 025 with on/off
switch and magnet
fixing
>>Daisy chain
>>On/off switch or movement sensor
>>Magnet, screw or clip fixing
The lamp series LED 025 is suitable for all types of panels and enclosures, especially where space is at a premium.
The lamps have a very long service life thanks to the use of LED technology. Three different fixing options provide
more flexibility for installation. The power output allows up to 10 lamps to be connected to each other (DC 12 V
versions up to 5 lamps). Both the power input and output connectors snap lock into their sockets. With the
integrated power unit and the plugs the lamp can quickly be connected.
TECHNICAL DATA
LED 025 with
on/off switch
and clip fixing
LED 025 with
movement sensor
and screw fixing
LED 025 with
clip fixing
LED 025 with
magnet or screw
fixing
Power consumption
max. 5 W
Luminosity
400 Lm at 120° (1,200 Lm at 360° or equivalent 95 W light bulb)
Lamp type
LED, angle of radiation 120°
light color: daylight, color temperature: 6,000 K to 7,000 K
Service life
60,000 h at +20 °C (+68 °F)
Connection
2-pole connector with snap lock
AC: max. 2.5 A / AC 240 V, color: white
DC: max. 2.5 A / DC 60 V, color: blue
Mounting
magnet fixing or screw fixing (M5), clip fixing (M6),
torque 2 Nm max.
Casing
plastic, transparent
Dimensions
see drawings
Weight
0.2 kg
Operating/Storage temperature
-30 to +60 °C (-22 to +140 °F) / -40 to +85 °C (-40 to +185 °F)
Operating/Storage humidty
max. 90 % RH (non-condensing)
Protection type/Protection class
IP20 / II (double insulated), DC 12 V: IP20 / III (extra-low voltage)
Mounting options: The lamps are available with magnet fixing for easy positioning in any steel cabinet or enclosure. A classic
is the LED 025 with screw fixing. The clip holders exclusively designed for clip fixing of the LED 025 can be positioned anywhere
in the cabinet by simply screwing the holders to the cabinet wall. The lamp is snapped into the clip holders and can be turned
351
250
in both directions. With a total rotation angle of 180° it provides perfect illumination within the cabinet or enclosure.
Note: The lamp must not be used for household lighting.
32
32
41
9,75
52
52
32
47,3
32
9,75
39
34
32
Side view clip fixing
36
32
Side view screw fixing
42
Side view magnet fixing
40
40
Art. No.
Magnet fixing
Art. No.
Screw fixing
Art. No.
Clip fixing
Operating voltage
Switch
02540.0-00
02540.0-01
02540.0-03
AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V)
on/off light switch
VDE
UL File No. E234324
EAC
02540.1-00
02540.1-01
02540.1-03
DC 24 – 48 V (min. DC 20 V, max. DC 60 V)
on/off light switch
VDE
UL File No. E234324
EAC
02540.2-00
02540.2-01
02540.2-03
DC 12 V (min. DC 10 V, max. DC 16 V)
on/off light switch
UL File No. E234324
EAC
02541.0-00
02541.0-01
02541.0-03
PIR movement sensor¹
VDE
UL File No. E234324
EAC
02541.1-00
02541.1-01
02541.1-03
VDE
UL File No. E234324
EAC
¹ approx. 5 min. fixed switch-on duration
Appovals
04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUCT CATALOGUE - STEGO
Connectors and cables for electrical connection are not included in the delivery of the LED 025. These parts can be ordered separately. Sets, consisting of lamp and accessories, are available on
request.
CONNECTION CABLE WITH FEMALE CONNECTOR AND OPEN END
Photo: Connection cable, Art. No. 244356
1
Art. No.
Model
Length
Voltage type
Color
Use for
244356
connection cable 2 x 1.5 mm² with female connector
2.0 m
AC
connector: white; cable: white
power input
Approvals²
VDE
244357
connection cable 2 x AWG 15 with female connector
2.0 m
AC
power input
VDE + UL
244360
connection cable 2 x 0.75 mm² with female connector
2.0 m
DC 24 – 48 V
connector: blue; cable: white
power input
VDE
244361
2.0 m
DC 24 – 48 V
power input
VDE + UL
244389
2.0 m
DC 12 VD
power input
VDE
244390
2.0 m
DC 12 V
power input
VDE + UL
Approvals²
² applies only to the individual components (cable and connectors)
EXTENSION CABLE WITH 2 CONNECTORS FOR DAISY CHAIN CONNECTION
Photo: Extension cable, Art. No. 244358
2
Art. No.
Model
Length
Voltage type
Color
Use for
244358
extension cable 2 x 1.5 mm² with 2 connectors
1.0 m
AC
connectors: white; cable: white
daisy chain
VDE
244359
extension cable 2 x AWG 15 with 2 connectors
1.0 m
AC
daisy chain
VDE + UL
244362
1.0 m
DC 24 – 48 V
connectors: blue; cable: white
daisy chain
VDE
244363
1.0 m
DC 24 – 48 V
daisy chain
VDE + UL
244391
1.0 m
DC 12 V
daisy chain
VDE
244392
1.0 m
DC 12 V
daisy chain
VDE + UL
FEMALE / MALE CONNECTORS
Photo: Female connector, Art. No. 264057
Photo: Male connector, Art. No. 264058
Art. No.
Model
Voltage type
Color
Use for
Approvals
264057
female connector
AC
white
power input
VDE + UL
264058
male connector
AC
white
power output
VDE + UL
264059
female connector
DC 24 – 48 V
blue
power input
VDE + UL
264060
male connector
DC 24 – 48 V
blue
power output
VDE + UL
264065
female connector
DC 12 V
blue
power input
VDE + UL
264066
male connector
DC 12 V
blue
power output
VDE + UL
CONNECTION EXAMPLE
1
2
This illustration shows the LED 025 lamp in a daisy chain application. The lamps are conveniently connected via quick connection plugs – up to 10 (5) lamps max. can be daisy-chained this way.
The snap lock connectors ensure a stable electrical connection even if subjected to heavy vibration. The connection example shows a AC 230 V application, using the following cables: connection
cable with female connector, Art. No. 244356 (1); daisy chain extension cable with 2 connectors, Art. No. 244358 (2).
Female/male connectors are also available to assemble cables in non-standard lengths.
ACCESSORIES
91 91
LIGHTING
STEGO - PRODUCT
CATALOGUE
TECHNICAL
DATASHEET
很抱歉,暂时无法提供与“02540.1-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+829.84716
- 10+777.41602
- 100+723.35405
- 国内价格 香港价格
- 1+888.740101+114.72890
- 10+832.5428010+107.47430
- 100+774.59481100+99.99370
