03115.0-00
03115.0-00
    STEGO
    插件
03115.0-00 数据手册
HVL 031 Fan Heater 100 - 400W Compact size Flat design Built-in overheat protection The compact HVL 031 high-performance fan heater prevents formation of condensation and provides an evenly distributed interior air temperature in enclosures. For large OEM use, this fan heater can also be provided without the fan, in which case the OEM/customer must provide a fan which meets the minimum airflow requirements. Shown: 100W - HVL 031 Fan Heater Heating 3-side DIN rail mountable | Technical Data Important! Heater must be operated together with a fan. Operating without a fan creates the danger of overheating. 100W/ 150W Heater 0.98” (25 mm) 0.87” (22 mm) 0.16” (4.2 mm) 3.15” (80 mm) 2.81” (71.5 mm) Mounting hole for DIN clip 2.68” (68 mm) high performance cartridge Overheat protection built-in temperature limiter Heater body die-cast aluminum, glass bead finish Connection 3-pole terminal AWG 14 max. (2.5mm²), torque 0.8Nm max.. Connection housing plastic, UL 94V-0, black Mounting clip for 35mm DIN rail, EN 60 715 Mounting position horizontal Operating / Storage temperature -49 to +158°F (-45 to +70°C) Protection class / Protection type I (grounded) / IP20 Axial fan, ball bearing service life 50,000h at 77°F (25°C) Air flow, free blowing see table below Axial fan connection 2-pole terminal AWG 14 max. (2.5mm²), terminals L2/N2 Approvals UL File No. E187294 (all), VDE (230VAC only) Air flow 1.26” (32 mm) Label Heating element Axial fan HVL 031 Fan Heater 0.71” (18 mm) 200W/ 300W/ 400W Heater 0.16” (4.2 mm) 4.68” (119 mm) 4.13” (104.8 mm) Mounting hole for DIN clip 0.98” (25 mm) 0.87” (22 mm) 2.68” (68 mm) Air flow 1.26” (32 mm) Label Thermostat 1 2 L N Axial fan Part No. - 120VAC Part No. - 230VAC Heating capacity Min. airflow (free blowing) Dimensions (as mounted) Weight (approx.) 03102.9-00 03102.0-00 100W 20 cfm (35m³/h) 1.85 x 3.15 x 4.41” (47 x 80 x 112mm) 1.3 lbs. (600g) 03103.9-00 03103.0-00 150W 20 cfm (35m³/h) 1.85 x 3.15 x 4.41” (47 x 80 x 112mm) 1.3 lbs. (600g) 03113.9-00 03113.0-00 200W 63 cfm (108m³/h) 1.85 x 4.68 x 5.94” (47 x 119 x 151mm) 2.0 lbs. (900g) 03114.9-00 03114.0-00 300W 63 cfm (108m³/h) 1.85 x 4.68 x 5.94” (47 x 119 x 151mm) 2.0 lbs. (900g) 03115.9-00 03115.0-00 400W 63 cfm (108m³/h) 1.85 x 4.68 x 5.94” (47 x 119 x 151mm) 2.0 lbs. (900g) Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application. STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com HVL031/2-11/US 0.71” (18 mm)
03115.0-00
物料型号:STEGO HVL 031
器件简介:这是一种高性能的风扇加热器,用于防止箱体内部形成冷凝水,并提供均匀分布的内部空气温度。它具有紧凑的尺寸和扁平设计,内置过热保护,并且可以三面安装在DIN导轨上。
引脚分配:加热器连接使用3极端子,最大AWG 14(2.5mm²),扭矩不超过0.8Nm。风扇连接使用2极端子,最大AWG 14(2.5mm²),端子为L2/N2。
参数特性: - 加热元件:高性能的筒式加热器 - 过热保护:内置温度限制器 - 加热器体:压铸铝,玻璃珠表面处理 - 连接盒:塑料,UL 94V-0,黑色 - 安装:35mm DIN导轨夹,符合EN 60 715标准 - 操作/存储温度:-49至+158°F(-45至+70°C) - 保护等级/类型:I(接地)/IP20 - 轴流风扇,滚珠轴承:在77°F(25°C)下使用寿命为50,000小时 - 风扇的空气流量:详见下表
功能详解:风扇加热器必须与风扇一起操作,以避免过热的危险。对于大型OEM使用,如果OEM/客户能提供满足最小气流要求的风扇,该风扇加热器也可以不配备风扇提供。
应用信息:适用于需要防止箱体内部形成冷凝水和需要均匀分布内部空气温度的场合。
封装信息:提供了不同功率型号的尺寸和重量信息,以及所需的最小空气流量。
03115.0-00 价格&库存
很抱歉,暂时无法提供与“03115.0-00”相匹配的价格&库存,您可以联系我们找货
