03504.0-01
03504.0-01
    STEGO
03504.0-01 数据手册
SD 035 Enclosure Receptacle Quick connections DIN rail mountable The DIN rail mounted electrical receptacle can be quickly fitted and connected in enclosures allowing the use of auxiliary products such as hand lamps and power tools. The unit is available with and without fuse, and in many world outlet standards. Electrical Receptacles Available with or without fuse Technical Data Connection 3 cage clamps for solid and stranded wire AWG 20-14 (0.5-2.5mm²) plastic, UL94 V-0, light grey Mounting clip for 35mm DIN rail, EN 60 715 Mounting position vertical Operating / Storage temperature -49 to +158°F (-45 to 70°C) Dimensions 3.6 x 2.4 x 1.9” (92 x 62 x 48mm) Weight approx. 7.1 oz. (200g) Protection class I (grounded) Protection type IP20 1.9” (48 mm) (1) 3.6” (92 mm) 2.4” (62 mm) Housing (2) FUSE (3) FUSE FUSE N N N (4) (5) (6) FUSE N FUSE N N N Part No. Operating Voltage max. Socket Model Nominal Current Approvals 03500.0-00 250VAC Germany/Russia (1) with fuse* 6.3A - 03500.0-01 250VAC Germany/Russia (1) without fuse 16.0A - 03501.0-00 250VAC France/Poland (2) with fuse* 6.3A - 03501.0-01 250VAC France/Poland (2) without fuse 16.0A - 03502.0-00 250VAC Switzerland (3) with fuse* 6.3A - 03502.0-01 250VAC Switzerland (3) without fuse 10.0A - 03503.0-00 250VAC UK/Ireland (4) with fuse* 6.3A - 03503.0-01 250VAC UK/Ireland (4) without fuse 13.0A - 03504.0-00 125VAC USA/Canada (5) with fuse* 6.3A UL File No. E222026 03504.0-01 125VAC USA/Canada (5) without fuse 15.0A UL File No. E222026 03505.0-00 250VAC Italy (6) with fuse* 6.3A - 03505.0-01 250VAC Italy (6) without fuse 16.0A - * fuse Ø 5 x 20 mm Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application. STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com SD035/2-09/US FUSE FUSE
03504.0-01 价格&库存
很抱歉,暂时无法提供与“03504.0-01”相匹配的价格&库存,您可以联系我们找货
    • 1+356.92044
    库存:14
