11802.0-00
11802.0-00
    STEGO
11802.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com FILTER FAN FF 018 | 136 CFM >>High air volume >>Functional design >>Time-saving installation >>UV resistant plastic Filter fans are used to provide an optimum climate in enclosures. The interior temperature of an enclosure can be reduced by channeling cooler filtered outside air into the enclosure thus expelling heated internal air. The resulting air flow prevents formation of localized heat pockets and protects the electronic components from overheating. The plastic used for the hood of this filter fan series is impact and UV light resistant. These filter fans are intended for indoor use. TECHNICAL DATA View from rear Axial fan, ball bearing service life min. 50,000 h at 77 °F (25 °C) and 65 %RH aluminum fan body, metal rotor Connection 3-pole clamp, AWG 14 (2.5 mm²), clamping torque 0.8 Nm max. Housing (filter fan and exhaust filter) plastic, UL 94V-0, light grey Hood (filter fan and exhaust filter) plastic, UL 94V-0, light grey; UV light resistant according to UL 746C (f1) Mounting frame with double-sided industrial adhesive for mounting to the outside of enclosure; certain operating circumstances may make the additional use of screws necessary; cut-out template included Filter media rating G4 acc. to DIN EN 779, filtering degree 94% Filter material synthetic fiber with progressive construction, temperature resistant to 212 °F, self-extinguishing class F1; moisture resistant to 100 %RH, reusable - can be cleaned by washing or vacuuming Operating / Storage temperature AC 120 V: -13 to +140 °F (-25 to +60 °C) AC 230 V: -13 to +122 °F (-25 to +50 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Protection class / Protection type I (grounded) / IP55 (according to VDE), UL Type 12 Approvals UL File No. E234324 (all), GOST TR (all), VDE (AC 230 V only) Exhaust filter Drilling template for mounting frame Part. No. Operating voltage Air volume, free blowing 01804.0-00 AC 230 V, 50 Hz¹ 118 cfm (200 m³/h) 01804.0-01 AC 120 V, 60 Hz 136 cfm (230 m³/h) Air volume with exhaust filter Current consumption Power consumption Average noise level (DIN EN ISO 4871) Mounting depth Enclosure cut-out Weight (approx.) 74 cfm (125 m³/h) 320 mA 45 W 52 dB (A) 3.7” (95 mm) 6.9 x 6.9” 3.7 lbs. (1.7 kg) 84 cfm (143 m³/h) 470 mA 39 W 52 dB (A) 3.7” (95 mm) 6.9 x 6.9” 3.7 lbs. (1.7 kg) EXHAUST FILTER EF 118 Part. No. Mounting depth Enclosure cut-out Weight (approx.) Filter mat Protection type 11802.0-00 0.6” (16 mm) 6.9 x 6.9” 1.3 lbs. (0.6 kg) G4 acc. to DIN EN 779, filtering degree 94% IP55² Part. No. Mounting depth Enclosure cut-out Weight (approx.) Filter mat Protection type 11802.0-00 0.6” (16 mm) 6.9 x 6.9” 1.3 lbs. (0.6 kg) G4 acc. to DIN EN 779, filtering degree 94% IP55² FILTER MATS FM 086 ¹ air volume increases by 15% when operating AC 230 V filter fans at 60 Hz, ² according to VDE 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Filter fan
11802.0-00 价格&库存
很抱歉,暂时无法提供与“11802.0-00”相匹配的价格&库存,您可以联系我们找货
