Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
PTC HEATER
HG 140 | 15 - 150 W
>>Compact size
>>Wide voltage range
>>Heating power adjusts to ambient
temperature
>>Cage clamp connectors for
quick & easy wiring
>>DIN rail mountable
TECHNICAL DATA
1
2
Operating voltage1
AC/DC 120-240 V (min. 110 V, max. 265 V)
Heating element
PTC resistor - temperature limiting
Heater body
extruded aluminum profile, anodized
Connection
3 cage clamps for solid wire AWG 20-14 (0.5-2.5 mm²), and
stranded wire (with wire end ferrule) - AWG 20-16 (0.5-1.5 mm²)
Connection casing
plastic, UL 94V-0, black
Mounting
clip for 35 mm DIN rail, EN 60715
Mounting position
vertical
Operating / Storage temperature
-49 to +158 °F (-45 to +70 °C)
Operating / Storage humidity
max. 90 %RH (non-condensing)
Protection class / Protection type
I (grounded) / IP20
Approvals
UL File No. E150057, VDE, GOST-R
Note
other voltages available upon request
Operating high voltage heaters below AC/DC 140 V reduces heating performance by approx. 10%.
Part No.
Heating capacity2
Max. current (inrush)
Length (L on dim. dwg.)
Weight (approx.)
14000.0-00
15 W
1.5 A
2.56” (65 mm)
7.6 oz. (215 g)
14001.0-00
30 W
3.0 A
2.56” (65 mm)
7.6 oz. (215 g)
14003.0-00
45 W
3.5 A
2.56” (65 mm)
7.6 oz. (215 g)
14005.0-00
60 W
2.5 A
5.5” (140 mm)
14.1 oz. (400 g)
14006.0-00
75 W
4.0 A
5.5” (140 mm)
14.3 oz. (405 g)
14007.0-00
100 W
4.5 A
5.5” (140 mm)
14.3 oz. (405 g)
14008.0-00
150 W
9.0 A
8.66” (220 mm)
21.3 oz. (600 g)
at 68 °F (20 °C) ambient temperature
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
These heaters are used in enclosures where damage from condensation must be prevented, or where the temperature
must be maintained above a minimum value. The aluminum profile heater body design has a chimney effect to
distribute heat evenly. The cage clamp connectors save time and simplify installation.
很抱歉,暂时无法提供与“14001.0-00”相匹配的价格&库存,您可以联系我们找货
