01011.0-31
01011.0-31
    STEGO
    STEGO - 01011.0-31 - THERMOSTAT, NO, 13A, 56VDC
01011.0-31 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com ELECTRONIC THERMOSTAT DCT 010 | DC 20 to 56 V >>High DC switching capacity >>Adjustable temperature >>Small hysteresis >>Optical operating display (LED) >>Integrated switch module >>Precise measurement via an external sensor TECHNICAL DATA 2.09" (53mm) 3.66" (93mm) 1.73" (44mm) 1 Switching difference (temperature) 3 K (±1 K tolerance) at +77 °F (+25 °C), 50 % RH Reaction time approx. 5 sec. External sensor cable 2 m with snap in connector (included in the delivery) Contact type contact maker NO (MOSFET) or contact breaker NC (MOSFET) Service life > 100,000 cycles Operating voltage DC 20 to 56 V Optical indicator LED Connection 6-pole terminal: stranded wire1 AWG 16 (1.5 mm²); max. AWG 12 (2.5 mm²) Mounting clip for 35 mm DIN rail, EN 60715 Housing plastic, UL 94V-0, grey (bicolor) Dimensions 3.7 x 2.1 x 1.7" (93 x 53 x 44 mm) Weight approx. 4.2 oz. (120 g) incl. sensor Mounting position vertical Storage temperature -40 to +176 °F (-40 to +80 °C) Operating / Storage humidity max. 90 % RH (non-condensing) Protection type IP20 Approvals UL File No. E164102, VDE, EAC Note other versions (e.g. setting ranges and °C) on request When connecting with stranded wires, wire end ferrules must be used. Wiring example Wiring diagram Heater +- 2 1 2 Part No. Max. switching capacity (relay output) Operating temperature Thermostat DCT 010 + Primary switching function setting range temperature Secondary switching function² humidity setting Contact (primary) Contact maker (NO) 01011.0-31 DC 13 A -22 °F to +122 °F (-30 °C to +50 °C) 14 to 122 °F - 01011.0-32 DC 11 A -22 °F to +140 °F (-30 °C to +60 °C) 32 to 140 °F - Contact maker (NO) 01011.0-61 DC 13 A -22 °F to +122 °F (-30 °C to +50 °C) 14 to 122 °F 65 % RH pre-set Contact breaker (NC) 01011.0-62 DC 11 A -22 °F to +140 °F (-30 °C to +60 °C) 32 to 140 °F 65 % RH pre-set Contact breaker (NC) V ersions with secondary switching function can also register the humidity and therefore offer an additional protection for electronics. Switching difference: 4 % RH (±1 % tolerance) at +77 °F (+25 °C), 50 % RH. 25.04.2018 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The electronic thermostat with integrated switch module is used to control DC powered devices with high capacities in control and switch cabinets. Heaters, coolers, filter fans or signal devices can directly be controlled via an internal electronic circuit. The external sensor can be positioned freely anywhere in the control cabinet for precise temperature measurements. Additionally, this thermostat is available in versions that not only measure temperature via the external sensor, but also the relative humidity.
01011.0-31 价格&库存
很抱歉,暂时无法提供与“01011.0-31”相匹配的价格&库存,您可以联系我们找货
