PTC
Small Heater
RC 016
These heaters are designed to prevent condensation in small enclosures
or to maintain minimum operating temperatures of electronic
components (for example, in camera housings, actuators, valve and
pump controls, telecom receivers/transmitters, control boxes, or micro
base stations).
PTC (Positive Temperature Coefficient) heating elements provide a "selfregulating" and "self-limiting" characteristic, making the heater safer and
more energy efficient (also see graph below).
Technical Data RC 016
0.07”
(1.8
mm)
0.12”
(3.2
mm)
24
01609.0-00
1.2" (30 mm)
18
0.07”
(1.8
mm)
0.18” 0.18”
(4.5 (4.5
mm) mm)
01609.0-00
13” (340 mm)
2 x AWG 22 (0.25 mm²)
Part. No. 01609.0-00
10
2.36”(60 mm)
01602.0-00
0.49” (12.5 mm)
0.07”
(1.8
mm)
-20 -10 0 10 20 30 40 50 60
-4 14 32 50 68 86 104 122 140
(°C)
(°F)
0.49” (12.5 mm)
6
13” (340 mm)
1.57” (40 mm)
0.18” 0.18”
(4.5mm) (4.5mm)
0.2”
(5mm)
8
Part. No. 01602.0-00
Part. No. 01610.0-00
: measured in open air
: measured with heater mounted on 100 x 100 x 2 mm
(4 x 4 x 0.08")aluminum plate
Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
STEGO, Inc. · 2270 Northwest Parkway · Suite 170 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
RC016-11-05/US
12
0.49” (12.5 mm)
0.49” (12.5 mm)
14
0.12" (3.2 mm)
1.97" (50 mm)
2 x AWG 18 (0.75 mm²)
0.18"
(4.5 mm)
0.7" (18 mm)
0.49” (12.5 mm)
26
01602.0-00
Weight
(approx.)
11.8" (300 mm)
1.2" (30 mm)
0.49” (12.5 mm)
01610.0-00
16
Surface
Temperature 2)
8W
2.0A approx. 302°F (150°C) 0.7 oz. (20 g)
13W*
212°F (100°C)*
10W
2.5A approx. 311°F (155°C) 1.0 oz. (30 g)
01609.0-00
17W*
239°F (115°C)*
13W
3.0A approx. 340°F (170°C) 1.4 oz. (40 g)
01610.0-00
23W*
280°F (140°C)*
1)
Wattages and temperatures indicated by * were measured with heater mounted to
an aluminum plate of 4 x 4 x 0.08” (100 x 100 x 2 mm) size.
2)
Surface temperatures were measured in open air of 68°F (20°C).
28
22
Max. current
(inrush)
01602.0-00
Heating Power in Relation to Ambient Temperature
AC/DC 110 - 250 V
(W)
30
Power at
68°F 1)
Part No.
AC/DC 110 - 250 V (also available in AC/DC 24 and 48 V)
3500 VAC 1 min.
Aluminum, anodized
PTC, self-regulating and temperature limiting
PTFE / Kapton
See illustration below
Screw mounting
II (double insulated)
IP 32
UL, VDE
0.2”
(5mm)
Operating voltage:
Dielectric strength:
Heating body:
Heating element:
Insulation:
Connection:
Mounting:
Protection class:
Protection type:
Agency approvals:
很抱歉,暂时无法提供与“01610.0-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+185.661161+23.96730
- 3+166.228453+21.45870
- 10+146.7082110+18.93880
- 国内价格
- 1+225.14716
- 25+224.86599
- 50+219.54452
- 100+219.25293
