1
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
FILTER FAN PLUS
FPI/FPO | 11.46 X 11.46" (291 X 291 MM)
> New air-flap outlet technology for
high airflow
> Easy mounting
> Protection type/Environmental
ratings by independent testing
agencies (VDE & UL)
> Two optional systems for optimal
airflow (FPI/FPO)
> Industry-common enclosure cut-out
sizes (5 sizes)
> Single filter mat system design
The Filter Fan Plus series encompasses a new air-flap technology on the air outlet side, thereby reaching an
unparalleled high degree of airflow. A unique ratchet mechanism is used for easy installation. It provides safe and
secure mounting while guaranteeing a tight seal. Depending on the requirements, there are two optional systems
available – the FPI or the FPO system (FPI = "in", FPO = "out"). The FPI system is the more commonly known
installation system, where a filter fan located in the lower part of the enclosure draws cleaner, cooler air into the
enclosure (airflow direction "In"). This system consists of a filter fan and exhaust filter. On opposite, with the newer
FPO system, the filter fan will be located in the upper area of the enclosure to draw warmer air out of the enclosure
(airflow direction "Out"). The FPO system consists of an intake filter and exhaust filter fan. The Filter Fan Plus series
has been designed for indoor use.
TECHNICAL DATA
warm
SYSTEM FPI
Exhaust Filter FPI 118
Axial fan, ball bearing
service life L10 at +104 °F (+40 °C): min. 76,000 h
metal impeller
Connection
3-pole clamp for AWG 14 (2.5 mm²), clamping torque 0.8 Nm max.
Housing, hood, flaps
plastic UL 94V-0, light grey;
UV light resistant according to UL 746C (f1)
Enclosure cut-out
11.46 x 11.46" (291 x 291 mm)
Mounting frame
4 built-in ratchet push levers for mounting (6 ratchet stops to
accommodate for wall thicknesses Gauge 9 to 19 or 1-4 mm).
Additional screw mounting possible if needed1.
Filter mat
G3 acc. to DIN EN 779, average arrestance Aa 84 %
Filter material
synthetic mesh with progressive construction,
temperature resistant to +212 °F (+100 °C), self-extinguishing class F1,
moisture resistant to 100 % RH, reusable
Operating temperature
50 Hz: -13 to +131 °F (-25 to +55 °C)
60 Hz: -13 to +95 °F (-25 to +35 °C)
Storage temperature
-40 to +158 °F (-40 to +70 °C)
Operating/Storage humidity
max. 75 % RH (non-condensing)
Protection type/Protection class
IP54 / I (grounded)
Environmental rating UL/NEMA
UL TYPE 12 / NEMA 12
Approvals
VDE, UL File No. E234324, EAC
Note
other voltages on request
Air-flaps
cold
Filter Fan FPI 018
Filter mat
1
Drilling hole markings for screw mounting are indicated on mounting frame.
AIRFLOW DIRECTION "IN": FILTER FAN FPI 018
Part No.
Operating voltage
Air volume,
free blowing
Air volume
with exhaust filter
01874.0-30
AC 230 V, 50/60 Hz
254.8 cfm (433m³/h) 219.5 cfm (373 m³/h)
01874.9-30
AC 115 V, 50/60 Hz
231.9 cfm (394 m³/h) 199.5 cfm (339 m³/h)
Current consumption
(50/60 Hz)
Power
consumption
Average noise level
(DIN EN ISO 4871)
Mounting depth
Weight
(approx.)
Filter mat
400/480 mA
95 W
62 dB (A)
6.3" (160 mm)
6.8 lbs. (3.1 kg)
G3
660/800 mA
90 W
61 dB (A)
6.3" (160 mm)
6.8 lbs. (3.1 kg)
G3
AIRFLOW DIRECTION "IN": EXHAUST FILTER FPI 118
Part No.
Mounting depth
Weight (approx.)
Air outlet
11874.0-00
2.0" (50 mm)
2.2 lbs. (1.0 kg)
12.02.2016 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
Filter fans are used to provide "cooling" by forced air-circulation in enclosures and cabinets containing eletrical/
electronic and other components. The interior temperature of an enclosure can be reduced by channelling cooler,
filtered outside air into the enclosure, thus expelling hot inside air. The resulting airflow prevents formation of
localized hot pockets and protects electronic components from overheating.
2
www.stegousa.com
warm
SYSTEM FPO
Filter Fan FPO 018
Air-flaps
Intake Filter FPO 118
cold
Filter mat
Part No.
Operating voltage
Air volume, free
blowing
Air volume
with exhaust filter
01884.0-00
AC 230 V, 50/60 Hz
427.9 cfm (727 m³/h) 243.1 cfm (413 m³/h)
01884.9-00
AC 115 V, 50/60 Hz
413.8 cfm (703 m³/h) 230.1 cfm (391 m³/h)
Current consumption
(50/60 Hz)
Power
consumption
Average noise level
(DIN EN ISO 4871)
Mounting depth
Weight
(approx.)
Air outlet
400/480 mA
95 W
63 dB (A)
6.3" (160 mm)
7.0 lbs. (3.2 kg)
air-flaps
660/800 mA
90 W
62 dB (A)
6.3" (160 mm)
7.0 lbs. (3.2 kg)
air-flaps
AIRFLOW DIRECTION "OUT": INTAKE FILTER FPO 118
Part No.
Mounting depth
Weight (approx.)
Filter mat
11884.0-30
1.0" (25 mm)
1.8 lbs. (0.8 kg)
FILTER MAT FM 086
Filter class
11.14 x 11.14" (283 x 283 mm)
Average arrestance Aa
1 packing unit
Part No. 08637.0-00
84 %
5 pieces
DIMENSIONED DRAWINGS
FPI 018
FPI 118
FPO 018
11.46" (291mm)
11.46" (291mm)
12.68" (322mm)
11.46"
11.46"
(291mm)
(291mm)
0.98"
0.98"
(25mm)
(25mm)
1.14"1.14"
0.98"
1.14"1.14"
6.30"
6.30"
(160mm)
(160mm)(29mm)
(29mm)
(25mm) 1.14"
(29mm)
(29mm)
1.14"
6.30" (160mm) (29mm)
(29mm)
12.68"
12.68"
(322mm)
(322mm)
11.46"
11.46"
(291mm)
(291mm)
1.97"1.97"1.14"1.14"
1.97"(50mm)
1.14"(29mm)
(50mm)
(29mm)
(50mm) (29mm)
11.46" (291mm)
11.46" (291mm)
11.46"
(291mm)
11.46"
(291mm)
11.46"
(291mm)
11.46"
(291mm)
1.14"1.14"
1.14"(29mm)
(29mm)
6.30"
6.30"
(160mm)
(160mm)
12.68"
12.68"
(322mm)
(322mm)
12.68" (322mm)
FPO 118
AIRFLOW DIRECTION "OUT": FILTER FAN FPO 018
很抱歉,暂时无法提供与“01874.9-30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1927.634691+249.39100
