01882.0-00
01882.0-00
    STEGO
    STEGO - 01882.0-00 - FILTER FAN, BALL, 230VAC, 45W, IP54
01882.0-00 数据手册
1 TECHNICAL DATASHEET FILTER FAN PLUS FPI/FPO | 176 x 176 mm >>New air-flap outlet technology for high airflow >>Easy mounting >>Protection type test/Environmental rating by independent testing institutes (VDE and UL) >>Two systems for optimal airflow (FPI/FPO) >>Standard enclosure cut-out sizes (5 sizes) >>One filter mat Filter fans are used to provide an optimum climate in enclosures and cabinets with electrical/electronic components. The interior temperature of an enclosure can be reduced by channelling cooler filtered outside air into the enclosure thus expelling heated internal air. The resulting airflow prevents formation of localised hot pockets in installations and protects electronic components from overheating. The Filter Fan Plus series uses a new air-flap outlet technology for the air outlet and thus reaches a high degree of airflow. A ratchet mechanism is used for mounting and provides high stability and tightness. Depending on the application there are two systems that are available – the FPI or FPO system. The FPI system is a standard installation with a filter fan in the lower part of the enclosure which ensures that fresh air is fed into the enclosure (airflow direction "In"). This system consists of a filter fan and exit filter. Whereas in the FPO system, the filter fan is located in the upper area of the enclosure to avoid heat buildups (airflow direction "Out"). The FPO system is composed of an intake filter and exit filter fan. The Filter Fan Plus series has been designed for indoor use. TECHNICAL DATA SYSTEM FPI warm Air outlet through flaps cold Air intake through filter mat with fan 1 Axial fan, ball bearing service life L10 at +40 °C (+104 °F): min. 65,000 h fan body aluminium, rotor metal Connection 3-pole clamp for 2.5 mm², clamping torque 0.8 Nm max. Casing, hood, flaps plastic according to UL94 V-0, light grey; UV light resistant according to UL746C (f1) Enclosure cut-out 176 x 176 mm Mounting frame 4 built-in ratchet braces for mounting (6 notches for wall thickness 1 — 4 mm). Additional use of screws possible if needed1. Filter mat G3 acc. to DIN EN 779, average arrestance Aa 84 % Filter material synthetic fibre with progressive construction, temperature resistant to +100 °C, self-extinguishing class F1, moisture resistant to 100 % RH, reusable Operating temperature 50 Hz: -25 to +50 °C (-13 to +122 °F) 60 Hz: -25 to +70 °C (-13 to +158 °F) Storage temperature -40 to +70 °C (-40 to +158 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP54 / I (earthed) Environmental rating UL/NEMA UL TYPE 12 / NEMA 12 Approvals VDE, UL File No. E234324, EAC Note other voltages on request Drilling marks for screw mounting are indicated on mounting frame. AIRFLOW DIRECTION "IN": FILTER FAN FPI 018 Art. No. Operating voltage Air volume, free flow Air volume with exit filter Current consumption (50/60 Hz) 01872.0-30 AC 230 V, 50/60 Hz 170 m³/h 113 m³/h 310/250 mA 01872.9-30 AC 115 V, 50/60 Hz 204 m³/h 137 m³/h 560/470 mA Power consumption Average noise level (DIN EN ISO 4871) Depth in enclosure Weight (approx.) Filter mat 45 W 55 dB 117 mm 1.6 kg G3 38 W 58 dB 117 mm 1.6 kg G3 AIRFLOW DIRECTION "IN": EXIT FILTER FPI 118 Art. No. Depth in enclosure Weight (approx.) Air outlet 11872.0-00 43 mm 0.4 kg air-flap outlet technology 15.10.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUKTKATALOG - STEGO 2 TECHNICAL 2 DATASHEET www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUKTKATALOG - STEGO SYSTEM FPO warm Air outlet through flaps with fan AIRFLOW DIRECTION "OUT": FILTER FAN FPO 018 Art. No. Operating voltage Air volume, free flow Air volume with exit filter Current consumption (50/60 Hz) 01882.0-00 AC 230 V, 50/60 Hz 263 m³/h 137 m³/h 310/250 mA 01882.9-00 AC 115 V, 50/60 Hz 313 m³/h 166 m³/h 560/470 mA Power consumption Average noise level (DIN EN ISO 4871) Depth in enclosure Weight (approx.) air outlet 45 W 56 dB 117 mm 1.6kg air-flaps 38 W 60 dB 117 mm 1.6kg air-flaps AIRFLOW DIRECTION "OUT": INTAKE FILTER FPO 118 Art. No. Depth in enclosure Weight (approx.) Filter mat 11882.0-30 25 mm 0.4 kg G3 acc. to DIN EN 779, average arrestance Aa 84 % FILTER MAT FM 086 Filter class 168 x 168 mm Average arrestance Aa 1 packing unit G3 acc. to DIN EN 779 Art. No. 08635.0-00 84 % 5 pieces 117 43 176 176 FPI 018 215 25 FPI 118 25 25 176 25 25 176 117 215 FPO 018 FPO 118 15.10.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. cold Air intake through filter mat
01882.0-00 价格&库存
很抱歉,暂时无法提供与“01882.0-00”相匹配的价格&库存,您可以联系我们找货
  • 1+1049.532801+136.21020
  • 50+945.5721150+122.71800
库存:37
01882.0-00
  • 1+1261.66760
  • 5+1223.81331
  • 12+1185.95901
  • 25+1160.71587
  • 50+1135.51438
库存:19
