02541.0-03-0003
02541.0-03-0003
    STEGO
    STEGO - 02541.0-03-0003 - LED LIGHT BAR, 6500K, 351MM, WHITE
02541.0-03-0003 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com LIGHT LED 025 LED 025 Light with on/off switch and magnet mount >> Energy saving LED technology >> Wide voltage range >> Integrated power unit >> Magnet, screw or clip mount >> Wide variety of connections >> On/off switch or motion sensor TECHNICAL DATA LED 025 Light with on/off switch and clip mount LED 025 Light with motion sensor and screw mount On/off switch light w/magnet or screw mount On/off switch light w/clip mount Power consumption max. 5 W (~ 75 W incandescent bulb) Luminosity 290 Lm at 120° (870 Lm at 360° or equivalent 75W light bulb) Lamp type LED, 120° angle of radiation light color - daylight, color temperature - 6,500 K Service life 60,000 hrs. at 68 °F (20 °C) Connection 2-pole plug with snap lock; AC: max. 2.5 A / AC 240 V, white connector; DC: max. 2.5 A / DC 60 V, blue connector Housing plastic, transparent Mounting magnet, M5 screws (not included), or clip (M6 screws) torque 2 Nm max. Operating / Storage temperature -22 to +140 °F (-30 to +60 °C) / -40 to +185 °F (-40 to +85 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Dimensions see drawings Protection type/Protection class IP20 / II (double insulated) Accessories input and output connector, cable for supply or daisy chain Approvals UL File No. E234324, VDE (except clip mount versions), GOST-R Mounting options: The lights are available with magnet mount for easy positioning in any steel cabinet or enclosure. Other options are the LED 025 with screw mount, and specifically designed clip holders for clip mount of the LED 025 can also be positioned anywhere in the cabinet. The clip holders are screwed to the cabinet wall, the lamp is simply snapped into the clip holders and can be rotated as needed for a perfect illumination. Magnet mount end view Screw mount end view Clip mount end view LIGHT KITS WITH INPUT CONNECTOR INCLUDED Part No. - magnet mount Part No. - screw mount Part No. - clip mount Operating voltage Switch type Weight 02540.0-00-0003 02540.0-01-0003 02540.0-03-0003 AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) on/off switch 4.8 oz. (135 g) 02540.1-00-0003 02540.1-01-0003 02540.1-03-0003 DC 24-48 V (min. DC 20 V, max. DC 60 V) on/off switch 4.8 oz. (135 g) 02541.0-00-0003 02541.0-01-0003 02541.0-03-0003 AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) PIR motion sensor¹ 5.0 oz. (140 g) 02541.1-00-0003 02541.1-01-0003 02541.1-03-0003 DC 24-48 V (min. DC 20 V, max. DC 60 V) PIR motion sensor¹ 5.0 oz. (140 g) ¹ Passive Infrared (PIR) motion sensor is factory pre-set to turn the light off 6 minutes after all motion ceases 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The LED 025 light series is suitable for all types of panels and enclosures, especially where space is at a premium. These lights have a very long service life due to the use of LED technology. They are available with powerful non-slip rubberized magnets allowing them to be easily positioned in any steel enclosure. Screw mounting is also available as an option. The power output allows up to 10 lights to be connected to each other (daisy chain) with both the input and output plugs snap-locking into place. www.stegousa.com Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com LIGHT ONLY Part No. magnet mount Part No. screw mount Part No. clip mount Operating voltage Switch type Weight 02540.0-00 02540.0-01 02540.0-03 AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) on/off switch 4.8 oz. (135 g) 02540.1-00 02540.1-01 02540.1-03 DC 24-48 V (min. DC 20 V, max. DC 60 V) on/off switch 4.8 oz. (135 g) 02541.0-00 02541.0-01 02541.0-03 AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) PIR motion sensor¹ 5.0 oz. (140 g) 02541.1-00 02541.1-01 02541.1-03 DC 24-48 V (min. DC 20 V, max. DC 60 V) PIR motion sensor¹ 5.0 oz. (140 g) ¹ Passive Infrared (PIR) motion sensor is factory pre-set to turn the light off 6 minutes after all motion ceases ACCESSORIES CONNECTION CABLE WITH INPUT CONNECTOR AND WIRE LEADS Part No. Model Length Voltage Color 244357 connection cable 2 x AWG 16 with input connector 2.0 m AC connector: white - cable: white Approvals² UL, VDE 244361 connection cable 2 x AWG 16 with input connector 2.0 m DC connector: blue - cable: white UL, VDE ² applies only to the individual components (cable and connectors) EXTENSION CABLE WITH 2 CONNECTORS FOR DAISY CHAIN (INPUT & OUTPUT) CONNECTION Photo: Extension cable, Part. No. 244359 2 Part No. Model Length Voltage Color Approvals² 244359 extension cable 2 x AWG 16 with 2 connectors 1.0 m AC connectors: white - cable: white UL, VDE 244363 extension cable 2 x AWG 16 with 2 connectors 1.0 m DC connectors: blue - cable: white UL, VDE ² applies only to the individual components (cable and connectors) INPUT / OUTPUT CONNECTORS Photo: Input connector, Part No. 264057 Photo: Output connector, Part No. 264058 Part No. Model Voltage Color 264057 input connector AC white Approvals UL, VDE 264058 output connector AC white UL, VDE 264059 input connector DC blue UL, VDE 264060 output connector DC blue UL, VDE CONNECTION EXAMPLE 1 2 This illustration shows the LED 025 light in a daisy chain application. The lights are easily connected via quick connection plugs - up to 10 lights can be daisy-chained this way. The snap-lock connectors ensure a stable electrical connection even when subjected to vibration. Input / output connectors are also available to assemble cables in non-standard lengths. 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Photo: Connection cable, Part No. 244357 1
02541.0-03-0003 价格&库存
很抱歉,暂时无法提供与“02541.0-03-0003”相匹配的价格&库存,您可以联系我们找货
