02820.0-06
02820.0-06
    STEGO
    STEGO - 02820.0-06 - Heater, 230 V, 400 W, 90 mm, 85 mm, 113 mm, 3.54 "
02820.0-06 数据手册
22TECHNICAL 22 HEATING DATASHEET COMPACT SEMICONDUCTOR FAN HEATER CSF 028 | 250 W, 400 W >>Small, compact design >>Integrated pre-set thermostat >>Dynamic heating up >>Touch-safe >>Quick connection >>Clip or screw flange fixing The compact fan heater prevents formation of condensation and provides an evenly distributed interior air temperature in enclosures with electric/electronic components. The touch-safe plastic housing and the small dimensions makes it ideal for use in enclosures with high packing density. The CSF 028 is equipped with a preset thermostat. It is connected via external clamps. The fan heater is available with two different mounting systems - either mounting by screw flange or by clip. The robust screw flange fixing is particularly suitable for applications with high vibration. CSF 028 with clip fixing TECHNICAL DATA CSF 028 with screw flange fixing Heating element PTC resistor - temperature limiting Surface temperature 250W: max. +50°C (+122°F), 400W: max. +65°C (+149°F) each except upper protective grille at +20°C (+68°F) ambient temperature Temperature safety cut-out to protect against overheatingin case of fan failure, automatic reset Axial fan, ball bearing air flow, free flow CSF 028: 45m³/h (230VAC), 54m³/h (120VAC) service life 40,000h at +40°C (+104°F) Connection 2-pole dual pressure clamp for rigid wire 2.5mm², stranded wire (with wire end ferrule) 1.5 mm² Casing plastic according to UL94 V-0, black Mounting clip for 35mm DIN rail, EN 60715 or screw fixing (Ø 5.5mm), lamping torque 2Nm max., washers have to be used Fitting position vertical airflow (air outlet up), horizontal airflow Dimensions models with clip fixing: 105 x 85 x 118mm, models with screw flange fixing: 105 x 115 x 108mm Weight 0.5kg Operating/Storage temperature -40 to +70°C (-40 to +158°F)/-45 to +70°C (-49 to +158°F) Operating/Storage humidity max. 90% RH (non-condensing) Protection type/Protection class IP20 / II (double insulated) Approvals VDE, UL File No. E150057, EAC Art. No. clip fixing Art. No. screw flange fixing Operating voltage Heating capacity¹ Inrush current max. Recommended pre-fuse T (time-delay) 02821.0-06 02821.0-08 230VAC, 50/60Hz 250W 9.0A 10.0A +15°C (+59°F) +5°C (+41°F) 02821.0-09 02821.0-11 230VAC, 50/60Hz 250W 9.0A 10.0A +25°C (+77°F) +15°C (+59°F) 02820.0-06 02820.0-08 230VAC, 50/60Hz 400W 15.0A 16.0A +15°C (+59°F) +5°C (+41°F) 02820.0-09 02820.0-11 230VAC, 50/60Hz 400W 15.0A 16.0A +25°C (+77°F) +15°C (+59°F) 02821.9-06 02821.9-08 120VAC, 50/60Hz 250W 6.0A 10.0A +15°C (+59°F) +5°C (+41°F) 02821.9-09 02821.9-11 120VAC, 50/60Hz 250W 6.0A 10.0A +25°C (+77°F) +15°C (+59°F) 02820.9-06 02820.9-08 120VAC, 50/60Hz 400W 9.0A 10.0A +15°C (+59°F) +5°C (+41°F) 02820.9-09 02820.9-11 120VAC, 50/60Hz 400W 9.0A 10.0A +25°C (+77°F) +15°C (+59°F) ¹ at +20°C (+68°F) ambient temperature; ² tolerance of ±5K Note: Other switch-off and switch-on temperatures on request. Switch-off temperature² Switch-on temperature² 20.03.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUCT CATALOGUE - STEGO 45 90 105 90 105 85 TECHNICAL DRAWINGS CLIP FIXING 113 85 Temperature (°C) View: back side SCREW FLANGE FIXING 115 103 108 Heating capacity / Ambient temperature diagram CSF 028 View: back side 103 Example of connection Fan heater CSF 028 www.stego.de | www.stego.co.uk | www.stegonorden.se HEATING 20.03.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Heating capacity (W) STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET 23 23 118
02820.0-06 价格&库存
很抱歉,暂时无法提供与“02820.0-06”相匹配的价格&库存,您可以联系我们找货
  • 1+1213.11830
库存:14
