03097.3-12
03097.3-12
    STEGO
03097.3-12 数据手册
30TECHNICAL 30 HEATING DATASHEET >>High DC heating performance >>Integrated thermostat or hygrostat (optional) >>Small hysteresis >>Integrated switch module >>Screw fixing >>Optical indicator (LED) The compact high performance fan heater prevents formation of condensation and frost and provides an evenly distributed interior air temperature in enclosures with electric/electronic components. The fan heater is available with an integrated electronic thermostat or integrated electronic hygrostat. The model with thermostat is available with internal or external sensor. The fan heater with integrated hygrostat is equipped with an external sensor. The external sensor can be positioned freely anywhere in the enclosure for precise measurements of temperature and humidity. The DCR 030 was designed as a stationary unit for the bottom of the enclosure. For wall fixing the fan heater DCR 130 is recommended. 100 TECHNICAL DATA 166 105 145 130 Heating element high performance cartridge Temperature safety cut-out with automatic reset and second-tier one shot fuse to protect against overheating in case of fan failure Heater body extruded aluminium profile Axial fan, ball bearing airflow 160 m³/h, free flow service life 50,000 h at +25 °C (+77 °F) Connection 2-pole „Push-In“ connection clamp stranded wire1 1.5 mm² (AWG 16) with strand relief; max. 2.5 mm² (AWG 12) Casing plastic according to UL94 V-0, black Mounting screw fixing (M5), torque 2 Nm max., washers have to be used Fitting position vertical airflow (air outlet up) Dimensions 166 x 145 x 100 mm Weight approx. 1.3 kg Operating temperature -20 to +75 °C (-4 to +167 °F) Storage temperature -40 to +80 °C (-40 to +176 °F) Operating / Storage humidity max. 90 % RH (non-condensing) Protection type / Protection class IP20 / II (double insulated) Approvals UL File No. E234324, VDE, EAC Note other versions (heating capacities, setting ranges) as well as operating voltage DC 48 V on request ¹ When connecting with stranded wires, wire end ferrules must be used. Connection diagram + M INT EXT 23.05.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. HIGH-PERFORMANCE FAN HEATER DCR 030 | DC 24 V, DC 56 V – 200 W to 800 W www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUCT CATALOGUE - STEGO Art. No. Model Operating voltage Heating capacity Recommended pre-fuse T (time-delay) Setting range3 temperature / humidity 03092.1-12 Thermostat with internal sensor DC 24 V 200 W 25.0 A -20 to +40 °C 03092.1-13 Thermostat with connector for external sensor² DC 24 V 200 W 25.0 A -20 to +40 °C 03097.3-12 Thermostat with internal sensor DC 56 V 800 W 25.0 A -20 to +40 °C 03097.3-13 Thermostat with connector for external sensor² DC 56 V 800 W 25.0 A -20 to +40 °C 03092.1-03 Hygrostat with connector for external sensor² DC 24 V 200 W 25.0 A 40 to 90 % RH 03095.3-03 Hygrostat with connector for external sensor² DC 56 V 600 W 25.0 A 40 to 90 % RH ² The external sensor needs to be ordered separately. ³ Switch difference temperature: 3 K (±1 K tolerance) at +25 °C (+77 °F), 50 % RH; switch difference humidity: 4 % RH (±1 % tolerance) at +25 °C (+77 °F), 50 % RH. ACCESSORIES The external sensor is not included in the delivery of the DCR 030. It can be ordered separately. EXTERNAL SENSOR The external sensor can be positioned freely anywhere in the enclosure for precise measurements of temperature and humidity. Art. No. Length 267071 1m 267072 2m 267126 3m www.stego.de | www.stego.co.uk | www.stegonorden.se 31 31 23.05.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. HEATING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET
03097.3-12 价格&库存
很抱歉,暂时无法提供与“03097.3-12”相匹配的价格&库存,您可以联系我们找货
    • 1+2442.656591+315.32650
    • 5+2171.211405+280.28520
