06011.0-00
06011.0-00
    STEGO
06011.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com TOUCH-SAFE PTC HEATER CSF 060 | 50-150 W >>Low surface temperature >>Integrated thermostat >>Compact size >>Wide voltage range >>Double insulated protection >>DIN rail mountable TECHNICAL DATA 1 Operating voltage1 AC 120-240 V (min. 110 V, max. 265 V) Heating capacity see table Heating element PTC resistor - temperature limiting Surface temperature < 176 °F (80 °C), except upper protective grill Connection 4-pole terminal AWG 14 max (2.5 mm²), torque 0.8 Nm max. Housing plastic, UL 94V-0, black Mounting clip for 35 mm DIN rail, EN 60715 Mounting position vertical Operating / Storage temperature -40 to +158 °F (-40 to +70 °C) / -49 to +158 °F (-45 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Protection class / Protection type II (double insulated) / IP20 Approvals VDE, GOST TR Operating high voltage heaters below AC 140 V reduces heating performance by approx. 10%. Wiring example Heating Power (W) CSF 060 Heater Ambient Temperature Part No. Heating capacity² Max. current (inrush) Air outlet temperature³ Switch-off temperature4 Switch-on temperature4 Dimensions Weight (approx.) 06001.0-00 50 W 2.5 A 187 °F (86 °C) 59 °F (15 °C) 41 °F (5 °C) 5.24 x 2.36 x 3.54” (133 x 60 x 90 mm) 10.8 oz. (305 g) 06002.0-00 50 W 2.5 A 187 °F (86 °C) 77 °F (25 °C) 59 °F (15 °C) 5.24 x 2.36 x 3.54” (133 x 60 x 90 mm) 10.8 oz. (305 g) 06011.0-00 100 W 4.5 A 248 °F (120 °C) 59 °F (15 °C) 41 °F (5 °C) 5.24 x 2.36 x 3.54” (133 x 60 x 90 mm) 11.2 oz. (320 g) 06012.0-00 100 W 4.5 A 248 °F (120 °C) 77 °F (25 °C) 59 °F (15 °C) 5.24 x 2.36 x 3.54” (133 x 60 x 90 mm) 11.2 oz. (320 g) 06021.0-00 150 W 8.0 A 293 °F (145 °C) 59 °F (15 °C) 41 °F (5 °C) 6.8 x 2.36 x 3.54” (173 x 60 x 90 mm) 15.9 oz. (450 g) 06022.0-00 150 W 8.0 A 293 °F (145 °C) 77 °F (25 °C) 59 °F (15 °C) 6.8 x 2.36 x 3.54” (173 x 60 x 90 mm) 15.9 oz. (450 g) see Heating Power / Ambient Temperature diagram; measured 2” (50 mm) above protective grill; tolerance of ± 5K Note: Other Switch-off and Switch-on temperatures on request 2 3 4 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The CSF 060 is a touch-safe heater for use in enclosures. The design of the heater utilizes natural convection which results in a circulating current of warm air. The surface temperatures on the accessible side surfaces of the housing are minimized as a result of the heater design. This model with plug-in thermostat does not require additional wiring. The CSF 060 is also available in a version without thermostat (CS 060).
06011.0-00 价格&库存
很抱歉,暂时无法提供与“06011.0-00”相匹配的价格&库存,您可以联系我们找货
  • 1+840.15714
  • 25+825.84852
  • 50+804.10443
  • 100+774.09175
  • 500+636.91028
库存:134
06011.0-00
  • 1+995.53283
  • 5+975.62336
  • 10+955.71389
  • 1+663.688311+85.67660
  • 10+611.8677510+78.98700
  • 50+573.3524750+74.01500
库存:96
