08600.0-00
08600.0-00
    STEGO
08600.0-00 数据手册
FF 018 Filter Fan 14 - 69 cfm Very low noise Minimal mounting depth Functional design Time-saving installation Filter fans are used to provide an optimum climate in enclosures. The interior temperature of an enclosure can be reduced by channeling cooler filtered outside air into the enclosure thus expelling heated internal air. The resulting air flow prevents formation of localized heat pockets and protects the electronic components from overheating. The plastic used for the hood of this filter fan series is highly weather resistant, as well as impact and UV light resistant. Ventilating Weather and UV resistant | Technical Data Axial fan, ball bearing service life min. 50,000h at 77°F (25°C) and 65% RH aluminum fan body, plastic rotor Connection 2 wires w/ cage clamps, AWG 14 (2.5mm²), length 4” (100mm) Housing (filter fan and exhaust filter) Plastic, UL 94V-0, light grey Hood (filter fan and exhaust filter) Plastic, UL 94V-0, light grey; weather and UV light resistant according to UL 746C (f1) Mounting frame with double-sided industrial adhesive for mounting to the outside of enclosure; certain operating circumstances may make the additional use of screws necessary; cut-out template included Filter media rating G4 acc. to DIN EN 779, filtering degree 94% Filter material synthetic fiber with progressive construction, temperature resistant to 212°F, self-extinguishing class F1; moisture resistant to 100% RH, reusable - can be cleaned by washing or vacuuming Enclosure ventilation using a filter fan and exhaust filter Operating / Storage temperature +14 to +158°F (-10 to +70°C) / -40 to +158°F (-40 to 70°C) Protection class I (grounded) Protection type IP55 (according to VDE), UL Type 1 Note: Using fine filter mat F5 increases the protection to UL Type 12 but reduces the air flow Special features The self-adhesive seal of the mounting frame prevents dust and water from entering the cabinet. Functional design of the intake and exhaust fan hoods very effectively prevents direct infiltration of falling water and dust. The advantage is that the filter mat does not rapidly become contaminated with dirt and therefore does not need to be exchanged as often. The air channeling makes the filter fan particularly quiet in operation. All filter fan models are also available with integrated airflow monitor. The direction of air flow can easily be switched by reversing the axial fan. 01800.0-00 230VAC, 50Hz1) 12 cfm (21m³/h ) Air volume Power Average noise level with exhaust filter consumption (DIN EN ISO 4871) 9 cfm (16m³/h) 13W 31dB (A) 1.8” (45mm) 3.8 x 3.8” 1.3 lbs. (0.6kg) 01800.0-01 120VAC, 60Hz 14 cfm (24m³/h) 11 cfm (18m³/h) 13W 31dB (A) 1.8” (45mm) 3.8 x 3.8” 1.3 lbs. (0.6kg) UL File No. E234324 01801.0-00 230VAC, 50Hz1) 32 cfm (55m³/h) 25 cfm (42m³/h) 15W 40dB (A) 2.3” (58mm) 4.9 x 4.9” 2.2 lbs. (1.0kg) UL File No. E234324, VDE 01801.0-01 120VAC, 60Hz Part No. 1) Operating voltage Air volume, free blowing Mounting depth Enclosure cut-out Weight (approx.) Approvals UL File No. E234324, VDE 37 cfm (63m³/h) 28 cfm (48m³/h) 15W 40dB (A) 2.3” (58mm) 4.9 x 4.9” 2.2 lbs. (1.0kg) UL File No. E234324 01802.0-00 230VAC, 50Hz1) 60 cfm (102m³/h) 40 cfm (68m³/h) 15W 39dB (A) 3.4” (86mm) 6.9 x 6.9” 2.9 lbs. (1.3kg) UL File No. E234324, VDE 01802.0-01 120VAC, 60Hz 46 cfm (78m³/h) 15W 39dB (A) 3.4” (86mm) 6.9 x 6.9” 2.9 lbs. (1.3kg) UL File No. E234324 69 cfm (117m³/h) air volume increases by 15% when operating 230VAC filter fans at 60Hz Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application. STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com FF018/2-11/US EMC versions and other voltages are available upon request. FF 018 Filter Fan 14 - 69 cfm Time-saving assembly and maintenance STEGO's filter fans are easily installed by one person from outside the cabinet. 1.) Make cut-out in the cabinet wall. The cut edge of the cabinet opening should be free of dirt, filings and grease. A template for the enclosure cut-out is included with the filter fan. Ventilating 2.) Remove protective film from the sealing strips on the mounting frame. Press mounting frame into the cabinet opening. The frame stays permanently in the cabinet. 3.) Electrically connect the axial fan using the cage clamp connectors. Push the unit into the mounting frame. Affix using screws if necessary. 4.) Insert the filter mat in the hood. Clip on. Finished. Installation sketch To change the filter mat, simply remove the filter hood, insert the new mat and snap the hood back again. No tools are required. Maintenance of the fan can easily be performed without removing the mounting frame (2). Dimensional Drawing 8.2” 3.4” 8.9” 6.7” 4.9” 5.3” 2.0” 6.2” 6.9” 1.6” 2.3” 5.1” 3.8” 1.4” 1.8” Drilling template for mounting frame Ø1/8” (3mm) Ø1/8” (3mm) 7.4” (188 mm) 5.4” (137 mm) 4.3” (109 mm) 7.4” (188 mm) 5.4” (137 mm) 4.3” (109 mm) Ø1/8” (3mm) EF 118 Exhaust Filter Part No. 11800.0-00 11801.0-00 11802.0-00 Mounting depth 0.6” (16mm) 0.6” (16mm) 0.6” (16mm) Enclosure cut-out 3.8 x 3.8” 4.9 x 4.9” 6.9 x 6.9” Weight (approx.) 0.6 lbs. (0.3kg) 0.8 lbs. (0.4kg) 1.3 lbs. (0.6kg) Filter mat G4 acc. to DIN EN 779, filtering degree 94% G4 acc. to DIN EN 779, filtering degree 94% G4 acc. to DIN EN 779, filtering degree 94% Protection type IP55* IP55* IP55* Approvals UL File No. E234324 UL File No. E234324 UL File No. E234324 FF018/2-11/US *according to VDE FM 086 Filter Mats Filter mat G4 (1 packing unit = 3 pcs.) F5 (1 packing unit = 3 pcs.) 3.5 x 3.5” (89 x 89mm) Part No. 08600.0-00 Part No. 08603.0-00 4.6 x 4.6” (118 x 118mm) Part No. 08601.0-00 Part No. 08604.0-00 6.6 x 6.6” (168 x 168mm) Part No. 08602.0-00 Part No. 08605.0-00 Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application. STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
08600.0-00
物料型号:文档列出了不同型号的过滤风扇,包括01800.0-00、01800.0-01、01801.0-00、01801.0-01、01802.0-00和01802.0-01。
器件简介:FF 018系列过滤风扇用于为机柜提供最佳气候条件,通过引入冷却过滤的外部空气并排出内部热空气来降低机柜内部温度,防止局部热点形成,保护电子元件免受过热。
引脚分配:风扇的电气连接使用带有笼式夹的2根电线,适用于AWG 14(2.5mm²)规格,长度为4英寸(100mm)。
参数特性:包括轴流风扇、球轴承、最低使用寿命为50,000小时、铝制风扇体、塑料转子等。
功能详解:过滤风扇具有自粘密封的安装框架,可防止灰尘和水进入机柜。进气和排气风扇罩的设计可有效防止直接渗透的落水和灰尘。风扇在运行中特别安静,所有型号的过滤风扇也可配备集成的气流监控器。
应用信息:过滤风扇适用于需要通风的机柜,以保持电子元件的适宜温度和防止过热。
封装信息:风扇的外壳和罩子均由UL 94V-0等级的塑料制成,耐候性强,UV光下稳定。
08600.0-00 价格&库存
很抱歉,暂时无法提供与“08600.0-00”相匹配的价格&库存,您可以联系我们找货
