08635.0-00
08635.0-00
    STEGO
    STEGO - 08635.0-00 - FILTER MAT, 6.61" X 6.61", GREY
08635.0-00 数据手册
1 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com FILTER FAN PLUS FPI/FPO | 6.93 X 6.93" (176 X 176 MM) > New air-flap outlet technology for high airflow > Easy mounting > Protection type/Environmental ratings by independent testing agencies (VDE & UL) > Two optional systems for optimal airflow (FPI/FPO) > Industry-common enclosure cut-out sizes (5 sizes) > Single filter mat system design The Filter Fan Plus series encompasses a new air-flap technology on the air outlet side, thereby reaching an unparalleled high degree of airflow. A unique ratchet mechanism is used for easy installation. It provides safe and secure mounting while guaranteeing a tight seal. Depending on the requirements, there are two optional systems available – the FPI or the FPO system (FPI = "in", FPO = "out"). The FPI system is the more commonly known installation system, where a filter fan located in the lower part of the enclosure draws cleaner, cooler air into the enclosure (airflow direction "In"). This system consists of a filter fan and exhaust filter. On opposite, with the newer FPO system, the filter fan will be located in the upper area of the enclosure to draw warmer air out of the enclosure (airflow direction "Out"). The FPO system consists of an intake filter and exhaust filter fan. The Filter Fan Plus series has been designed for indoor use. TECHNICAL DATA warm SYSTEM FPI Exhaust Filter FPI 118 Axial fan, ball bearing service life L10 at +104 °F (+40 °C): min. 65,000 h fan body aluminum, metal impeller Connection 3-pole clamp for AWG 14 (2.5 mm²), clamping torque 0.8 Nm max. Housing, hood, flaps plastic UL 94V-0, light grey; UV light resistant according to UL 746C (f1) Enclosure cut-out 6.93 x 6.93" (176 x 176 mm) Mounting frame 4 built-in ratchet push levers for mounting (6 ratchet stops to accommodate for wall thicknesses Gauge 9 to 19 or 1-4 mm). Additional screw mounting possible if needed1. Filter mat G3 acc. to DIN EN 779, average arrestance Aa 84 % Filter material synthetic mesh with progressive construction, temperature resistant to +212 °F (+100 °C), self-extinguishing class F1, moisture resistant to 100 % RH, reusable Operating temperature 50 Hz: -13 to +122 °F (-25 to +50 °C) 60 Hz: -13 to +158 °F (-25 to +70 °C) Storage temperature -40 to +158 °F (-40 to +70 °C) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP54 / I (grounded) Environmental rating UL/NEMA UL TYPE 12 / NEMA 12 Approvals VDE, UL File No. E234324, EAC Note other voltages on request Air-flaps cold Filter Fan FPI 018 Filter mat 1 Drilling hole markings for screw mounting are indicated on mounting frame. AIRFLOW DIRECTION "IN": FILTER FAN FPI 018 Part No. Operating voltage Air volume, free blowing 01872.0-30 AC 230 V, 50/60 Hz 100 cfm (170 m³/h) 01872.9-30 AC 115 V, 50/60 Hz 120 cfm (204 m³/h) Air volume with exhaust filter Current consumption (50/60 Hz) Power consumption Average noise level (DIN EN ISO 4871) Mounting depth Weight (approx.) Filter mat 81.8 cfm (139 m³/h) 310/250 mA 110.1 cfm (187 m³/h) 560/470 mA 45 W 55 dB (A) 4.6" (117 mm) 3.5 lbs. (1.6 kg) G3 38 W 58 dB (A) 4.6" (117 mm) 3.5 lbs. (1.6 kg) G3 AIRFLOW DIRECTION "IN": EXHAUST FILTER FPI 118 Part No. Mounting depth Weight (approx.) Air outlet 11872.0-00 1.7" (43 mm) 0.9 lbs. (0.4 kg) air-flap outlet technology 16.12.2015 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Filter fans are used to provide "cooling" by forced air-circulation in enclosures and cabinets containing eletrical/ electronic and other components. The interior temperature of an enclosure can be reduced by channelling cooler, filtered outside air into the enclosure, thus expelling hot inside air. The resulting airflow prevents formation of localized hot pockets and protects electronic components from overheating. 2 www.stegousa.com Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com warm SYSTEM FPO Filter Fan FPO 018 Air-flaps Intake Filter FPO 118 cold Filter mat Part No. Operating voltage Air volume, free blowing Air volume with exhaust filter Current consumption (50/60 Hz) 01882.0-00 AC 230 V, 50/60 Hz 154.8 cfm (263 m³/h) 80.6 cfm (137 m³/h) 310/250 mA 01882.9-00 AC 115 V, 50/60 Hz 184.2 cfm (313 m³/h) 97.7 cfm (166 m³/h) 560/470 mA Power consumption Average noise level (DIN EN ISO 4871) Mounting depth Weight (approx.) Air outlet 45 W 56 dB (A) 4.6" (117 mm) 3.5 lbs. (1.6 kg) air-flaps 38 W 60 dB (A) 4.6" (117 mm) 3.5 lbs. (1.6 kg) air-flaps AIRFLOW DIRECTION "OUT": INTAKE FILTER FPO 118 Part No. Mounting depth Weight (approx.) Filter mat 11882.0-30 1.0" (25 mm) 0.9 lbs. (0.4 kg) G3 acc. to DIN EN 779, average arrestance Aa 84 % FILTER MAT FM 086 Filter class 6.61 x 6.61" (168 x 168 mm) Average arrestance Aa 1 packing unit G3 acc. to DIN EN 779 Part No. 08635.0-00 84 % 5 pieces DIMENSIONED DRAWINGS FPI 018 8.47"8.47" (215mm) (215mm) 8.47" (215mm) FPI 118 FPO 018 6.93" (176mm) 6.93" 6.93" (176mm) (176mm) 6.93" (176mm) 6.93" 6.93" (176mm) (176mm) 6.93" (176mm) 8.47" (215mm) 0.98" 0.98" (25mm) (25mm) 0.98" (25mm) 6.93" (176mm) 6.93" (176mm) 4.61" (117mm) 0.98"0.98" (25mm) (25mm) 4.61" 4.61" (117mm) (117mm) 0.98"0.98" 0.98" 0.98"0.98" (25mm) (25mm) (25mm) (25mm) (25mm) 4.61" (117mm) 0.98" 0.98" (25mm) (25mm) 6.93" (176mm) 6.93" (176mm) 8.47" 8.47" (215mm) (215mm) 1.69" 1.69" (43mm) (43mm) 1.69" 0.98" 0.98" (43mm) (25mm) (25mm) 0.98" (25mm) 6.93" (176mm) 4.61" 4.61" (117mm) (117mm) FPO 118 16.12.2015 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. AIRFLOW DIRECTION "OUT": FILTER FAN FPO 018
08635.0-00 价格&库存
很抱歉,暂时无法提供与“08635.0-00”相匹配的价格&库存,您可以联系我们找货
