28404.0-00
28404.0-00
    STEGO
    STEGO - 28404.0-00 - VENT PLUG, ENCLOSURE, ALUMINIUM, 220L/H
28404.0-00 数据手册
> High degree of protection > Waterproof membrane > Corrosion resistant > Food safe Pressure differentials in enclosures with a high degree of protection are a result of internal and external temperature changes. In the case of negative pressure or partical vacuum, dust and humidity can enter the enclosure through the door seal. When the air inside the enclosure cools down, condensation may occur because the humidity cannot escape the enclosure. The easy-to-install pressure compensation device DA 284 provides compensation of pressure at a protection degree of IP66/IP67. Even with a slight overpressure, a waterproof membrane inside the plug allows the humidity to escape whilst blocking water and dirt from entering the enclosure. Photo: M40 in stainless steel TECHNICAL DATA Photo: M12 in aluminium Torque 5 Nm Depth in enclosure approx. 9 mm Sealing sealing gasket NBR Filter waterproof membrane Dimensions M40: Ø 58 x 31 mm, M12: Ø 17 x 21 mm Fitting position variable Operating/Storage temperature -35 to +80 °C (-31 to +176 °F) Approvals EAC Note Material adheres to limit values in accordance with RoHS3 Installation: Make cut-out Ø 40.5+0,5 mm for size M40/ Ø 12+ 0,2 mm for size M12 in enclosure wall and mount pressure compensation device with nut. Please make sure that the sealing gasket is put in place on the outer side panel of the enclosure. 1 2 Art. No. Thread Material Protection type Air permeability 1 packaging unit 28401.0-00 M40 x 1,5 V2A (DIN 1.4305 / AISI 303)1 IP66 (EN 60529) / IPX9K (EN 40050-9) 1.200 l/h 1 piece 0,2 kg 28401.0-02 M40 x 1,5 V4A (DIN 1.4404 / AISI 316L) IP66 (EN 60529) / IPX9K (EN 40050-9) 1.200 l/h 1 piece 0,2 kg 28404.0-00 M12 x 1,5 Nickel-plated aluminum2 IP67 220 l/h 1 piece 0,009 kg V2A is not sea waterproof Corrosion test according to ISO 9227:2017 Weight (approx.) 30.11.2021 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. PRESSURE COMPENSATION DEVICE (STAINLESS STEEL/ALUMINIUM) DA 284 | IP66 / IP67 www.stego.de | www.stego.co.uk | www.stegonorden.se 103103 ACCESSORIES STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET
28404.0-00 价格&库存
很抱歉,暂时无法提供与“28404.0-00”相匹配的价格&库存,您可以联系我们找货
    库存:41
