CR 02700.0-00
CR 02700.0-00
    STEGO
    STEGO - CR 02700.0-00 - PTC FAN HEATER, 650W, 32°F-140°F,120V
CR 02700.0-00 数据手册
CR 027 PTC Fan Heater 400 - 650W Compact fan heater Heating power adjusts to ambient temperature Integrated adjustable thermostat Built-in overheat protection The semiconductor CR 027 fan heater prevents the formation of condensation and ensures an even temperature in enclosures. The integrated thermostat is used to set the desired temperature while the high performance axial fan provides forced air circulation. The CR 027 is also available with a continuously running fan (when powered). Heating DIN rail mountable 3.94” (100 mm) | Technical Data 5” (128 mm) 6.5” (165 mm) 4.8” (124 mm) Wiring note: Only connect the L and N1 terminals - N2 is not Heating element PTC resistor - temperature limiting Overheat protection built-in temperature limiter Axial fan, ball bearing service life 50,000h at 77°F (25°C) Air flow, free blowing see table below Connection 2-pole terminal AWG 14 max. (2.5mm²), torque 0.8Nm max.. Housing plastic, UL 94V-0, light grey Function control light LED Mounting clip for 35mm DIN rail, EN 60 715 Mounting position vertical Operating / Storage temperature -49 to +158°F (-45 to +70°C) Dimensions 6.5 x 3.94 x 5.0” (165 x 100 x 128mm) Protection class II (double insulated) Protection type IP20 Approvals UL File No. E204590 used and Grounding is not required Heating Power / Ambient Temperature (@ 50Hz) Heating Power / Ambient Temperature (@ 60Hz) 900 850 Heating Power (W) Heating Power (W) 800 750 700 650 600 650W 550 500 550W 450 -20°C -4°F 0°C 32°F 20°C 68°F 400 -40°C -40°C -40°F -40°F 40°C 104°F Part No. 02700.0-00 02701.0-00 02700.9-00 02701.9-00 1) at Heating (@ 50Hz) 475W 550W 400W 510W 0°C 0°C 32°F 32°F 20°C 20°C 68°F 68°F 40°C 40°C 104°F 104°F Temperature Temperature capacity1) -20°C -20°C -4°F -4°F capacity1) Heating (@ 60Hz) 550W 650W 550W 650W 220-240VAC 220-240VAC Max. current (inrush) 11.0A 13.0A Air flow, free blowing 20 cfm (35m³/h) 26 cfm (45m³/h) Thermostat setting range 0 to 60°C 0 to 60°C Weight (approx.) 2.0 lbs. (0.9kg ) 2.4 lbs (1.10kg) 100-120VAC 100-120VAC 14.0A 15.0A 20 cfm (35m³/h) 26 cfm (45m³/h) 32 to 140°F 32 to 140°F 2.0 lbs. (0.9kg ) 2.4 lbs (1.10kg) Operating voltage 68°F (20°C) ambient temperature Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application. STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com CR027/2-09/US -40°C -40°F
CR 02700.0-00
物料型号为 STEGO CR 027 PTC Fan Heater。
器件简介包括其为紧凑型风扇加热器,具备环境温度调节加热功率、集成可调温控器、内置过热保护以及DIN导轨安装功能。
引脚分配包含2极接线端子,最大AWG 14(2.5mm²),扭矩不超过0.8Nm。
参数特性涵盖PTC电阻温度限制加热元件、内置温度限制器、轴流风扇(球轴承)、空气流量、连接方式、塑料外壳、LED功能控制灯、垂直安装位置、操作/存储温度范围、尺寸、防护等级和认证等。
功能详解包括防止结露和确保箱体内部温度均匀,以及设置所需温度和强制空气循环。
应用信息中提到,该半导体风扇加热器用于防止结露和确保箱体内部温度均匀。
封装信息指的是其尺寸为165x100x128mm,防护等级为IP20,并且为II级双重绝缘。
CR 02700.0-00 价格&库存
很抱歉,暂时无法提供与“CR 02700.0-00”相匹配的价格&库存,您可以联系我们找货
