1 TECHNICAL
1
DATASHEET
FILTER FAN PLUS
FPI/FPO | 291 x 291 mm
>>New air-flap outlet technology for
high airflow
>>Easy mounting
>>Protection type test/Environmental
rating by independent testing institutes
(VDE and UL)
>>Two systems for optimal airflow
(FPI/FPO)
>>Standard enclosure cut-out sizes
(5 sizes)
>>One filter mat
Filter fans are used to provide an optimum climate in enclosures and cabinets with electrical/electronic components.
The interior temperature of an enclosure can be reduced by channelling cooler filtered outside air into the enclosure
thus expelling heated internal air. The resulting airflow prevents formation of localised hot pockets in installations
and protects electronic components from overheating.
The Filter Fan Plus series uses a new air-flap outlet technology for the air outlet and thus reaches a high degree
of airflow. A ratchet mechanism is used for mounting and provides high stability and tightness. Depending on the
application there are two systems that are available – the FPI or FPO system. The FPI system is a standard installation
with a filter fan in the lower part of the enclosure which ensures that fresh air is fed into the enclosure (airflow
direction "In"). This system consists of a filter fan and exit filter. Whereas in the FPO system, the filter fan is located
in the upper area of the enclosure to avoid heat buildups (airflow direction "Out"). The FPO system is composed of
an intake filter and exit filter fan. The Filter Fan Plus series has been designed for indoor use.
TECHNICAL DATA
SYSTEM FPI
warm
Air outlet
through flaps
cold
Air intake
through filter mat
with fan
1
Axial fan, ball bearing
service life L10 at +40 °C (+104 °F): min. 76,000 h
rotor metal
Connection
3-pole clamp for 2.5 mm², clamping torque 0.8 Nm max.
Casing, hood, flaps
plastic according to UL94 V-0, light grey;
UV light resistant according to UL746C (f1)
Enclosure cut-out
291 x 291 mm
Mounting frame
4 built-in ratchet braces for mounting
(6 notches for wall thickness 1 — 4 mm).
Additional use of screws possible if needed1.
Filter mat
G3 acc. to DIN EN 779, average arrestance Aa 84 %
Filter material
synthetic fibre with progressive construction,
temperature resistant to +100 °C, self-extinguishing class F1,
moisture resistant to 100 % RH, reusable
Operating temperature
50 Hz: -25 to +55 °C (-13 to +131 °F)
60 Hz: -25 to +35 °C (-13 to +95 °F)
Storage temperature
-40 to +70 °C (-40 to +158 °F)
Operating/Storage humidity
max. 75 % RH (non-condensing)
Protection type/Protection class
IP54 / I (earthed)
Environmental rating UL/NEMA
UL TYPE 12 / NEMA 12
Approvals
VDE, UL File No. E234324, EAC
Note
other voltages on request
Drilling marks for screw mounting are indicated on mounting frame.
AIRFLOW DIRECTION "IN": FILTER FAN FPI 018
Art. No.
Operating voltage
Air volume,
free flow
Air volume
with exit filter
01874.0-30
AC 230 V, 50/60 Hz
433 m³/h
320 m³/h
01874.9-30
AC 115 V, 50/60 Hz
394 m³/h
289 m³/h
Current consumption
(50/60 Hz)
Power
consumption
Average noise level
(DIN EN ISO 4871)
Depth in
enclosure
Weight
(approx.)
Filter mat
400/480 mA
95 W
62 dB
160 mm
3.1 kg
G3
660/800 mA
90 W
61 dB
160 mm
3.1 kg
G3
AIRFLOW DIRECTION "IN": EXIT FILTER FPI 118
Art. No.
Depth in enclosure
Weight (approx.)
Air outlet
11874.0-00
50 mm
1.0 kg
15.10.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUKTKATALOG - STEGO
2 TECHNICAL
2
DATASHEET
SYSTEM FPO
warm
Air outlet through
flaps with fan
AIRFLOW DIRECTION "OUT": FILTER FAN FPO 018
Art. No.
Operating voltage
Air volume,
free flow
Air volume
with exit filter
01884.0-00
AC 230 V, 50/60 Hz
727 m³/h
413 m³/h
01884.9-00
AC 115 V, 50/60 Hz
703 m³/h
391 m³/h
Current consumption
(50/60 Hz)
Power
consumption
Average noise level
(DIN EN ISO 4871)
Depth in
enclosure
Weight
(approx.)
air outlet
400/480 mA
95 W
63 dB
160 mm
3.2 kg
air-flaps
660/800 mA
90 W
62 dB
160 mm
3.2 kg
air-flaps
AIRFLOW DIRECTION "OUT": INTAKE FILTER FPO 118
Art. No.
Depth in enclosure
Weight (approx.)
Filter mat
11884.0-30
25 mm
0.8 kg
FILTER MAT FM 086
Filter class
283 x 283 mm
Average arrestance Aa
1 packing unit
Art. No. 08637.0-00
84 %
5 pieces
TECHNICAL DRAWINGS
25
50
29
291
FPI 018
322
160
FPI 118
29
29
291
29
291
160
291
322
FPO 018
FPO 118
cold
Air intake
through filter mat
很抱歉,暂时无法提供与“01884.0-00”相匹配的价格&库存,您可以联系我们找货
