Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
TOUCH-SAFE PTC HEATER
CS 060 | 50 - 150 W
>>Low surface temperature
>>Compact size
>>Wide voltage range
>>Double insulated protection
>>DIN rail mountable
TECHNICAL DATA
1
Operating voltage1
AC/DC 120-240 V (min. 110 V, max. 265 V)
Heating capacity
see table
Heating element
PTC resistor - temperature limiting
Surface temperature
< 176 °F (80 °C), except upper protective grill
Connection
4-pole terminal AWG 14 max (2.5 mm²), torque 0.8 Nm max.
Housing
plastic, UL 94V-0, black
Mounting
clip for 35 mm DIN rail, EN 60715
Mounting position
vertical
Operating / Storage temperature
-49 to +158 °F (-45 to +70 °C)
Operating / Storage humidity
max. 90 %RH (non-condensing)
Protection class / Protection type
II (double insulated) / IP20
Approvals
UL File No. E150057, VDE, GOST TR
Note
other voltages available upon request
Operating high voltage heaters below AC/DC 140 V reduces heating performance by approx. 10%.
Wiring examples
CS 060 Heater
CS 060 Heater
Heating Power (W)
Thermostat
AC
CS 060 Heater
Thermostat
Ambient Temperature
AC
2
Part No.
Heating capacity²
Max. current (inrush)
Air outlet temperature3
Dimensions
06000.0-00
50 W
2.5 A
187 °F (86 °C)
4.3 x 2.36 x 3.54” (110 x 60 x 90 mm)
10.4 oz. (295 g)
06010.0-00
100 W
4.5 A
248 °F (120 °C)
10.6 oz. (300 g)
06020.0-00
150 W
8A
293 °F (145 °C)
5.9 x 2.36 x 3.54” (150 x 60 x 90 mm)
15.5 oz. (440 g)
see Heating Power / Ambient Temperature diagram; measured 2” (50 mm) above protective grill
3
Weight (approx.)
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The CS 060 is a touch-safe heater for use in enclosures. The design of the heater utilizes natural convection
which results in a circulating current of warm air. The surface temperatures on the accessible side surfaces of the
housing are minimized as a result of the heater design. The CS 060 is also available in a version with a plug-in
thermostat requiring no additional wiring (CSF 060).
很抱歉,暂时无法提供与“06010.0-00”相匹配的价格&库存,您可以联系我们找货
