28405.0-00
28405.0-00
    STEGO
28405.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com VENT PLUG DA 284 >>UL Type 1, 4, 4X & IP66 protection >>Waterproof membrane >>Easy to install >>Two sizes - M40 & M12 Pressure differentials in a hermetically sealed enclosure are a result of the heat generated by electrical and electronic components in the enclosure, as well as the fluctuation of the outside temperature. In the case of negative pressure or vacuum, for example, dust and humidity can enter the enclosure trough the door seal. The DA 284 Vent Plug provides a protected enclosure environment for valuable and crucial components with a UL 4X rated degree of protection. A waterproof membrane inside the device allows air and humidity to leave the enclosure while not allowing moisture and dust from the outside to enter. TECHNICAL DATA Photo: DA 284, M12 Mounting thread with nut (see below) Torque 5 Nm (max. 10 Nm) Material plastic according to UL 94V-0, light grey, weather and UV light resistant according to UL 746C (f1) Sealing NBR gasket Filter waterproof membrane Operating / Storage temperature -31 to +158 °F (-35 to 70 °C) Protection type see below Agency approvals UL File No. E234324 Environmental rating Type 1, 4 and 4X Installation Make cut-out in enclosure wall of diameter 1.58 inches (40-40.2 mm) for size M40 or 0.48 inches (12-12.2 mm) for size M12, and mount vent plug with nut. Make sure that the sealing gasket is placed on the outer side of the enclosure. For optimal pressure compensation, it is recommended to use two devices on opposite sides towards the top of the enclosure. Dimensional drawing: DA 284, M12 (drawing is not proportional to M40) Dimensional drawing: DA 284, M40 Part No. Modelç Thread length (depth in enclosure) Protection type Air permeability¹ 28405.0-00 28406.0-00 M40 x 1.5 approx. 16 mm IP66 (EN 60529) / IPX9K (EN 40050-9) M12 x 1.5 approx. 10 mm IP66 (EN 60529) ¹ at a pressure difference of min. 70 mbar 1 packing unit Weight (approx.) 1200 liters/hr 2 pieces 3.2 oz. (90 g) total 120 liters/hr 2 pieces 0.14 oz. (4 g) total 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Photo: DA 284, M40
28405.0-00 价格&库存
很抱歉,暂时无法提供与“28405.0-00”相匹配的价格&库存,您可以联系我们找货
