01012.0-21
01012.0-21
    STEGO
    STEGO - 01012.0-21 - ELECTRONIC HYGROSTAT, 3.7X2.1X1.7IN, 56V
01012.0-21 数据手册
>>High DC switching capacity >>Adjustable humidity >>Small hysteresis >>Optical operating display (LED) >>Integrated switch module >>Precise measurement via an external sensor The electronic hygrostat with integrated switch module is used to control DC powered devices with high capacities in control and switch cabinets. Heaters, coolers, filter fans or signal devices can directly be controlled via an internal electronic circuit. The external sensor can be positioned freely anywhere in the control cabinet for precise measurement of the atmospheric humidity. Additionally, this hygrostat is available in versions that not only measure the relative humidity via the external sensor, but also the temperature. TECHNICAL DATA 53 93 44 Switch difference (humidity) 4 % RH (±1 % tolerance) at +25 °C (+77 °F), 50 % RH Reaction time approx. 5 sec. External sensor cable 2 m with snap in connector (included in the delivery) Contact type contact maker NO (MOSFET) or contact breaker NC (MOSFET) Service life > 100,000 cycles Operating voltage DC 20 to 56 V Optical indicator LED Connection 6-pole terminal: stranded wire1 1.5 mm² (AWG 16); max. 2.5 mm² (AWG 12) Mounting clip for 35 mm DIN rail, EN 60715 Casing plastic according to UL94 V-0, grey (bicolor) Dimensions 93 x 53 x 44 mm Weight approx. 120 g (incl. sensor) Fitting position vertical Storage temperature -40 to +80 °C (-40 to +176 °F) Operating / Storage humidity max. 90 % RH (non-condensing) Protection type IP20 Approvals UL File No. E164102, VDE, EAC Note other versions on request When connecting with stranded wires, wire end ferrules must be used. 1 Example of connection Connection diagram Heater +- 2 Hygrostat DCF 010 2 1 + Art. No. Max. switching capacity Operating temperature Primary switching function setting range humidity Secondary switching function² Switch-on temperature Contact (primary) 01012.0-20 DC 15 A -30 to +40 °C (-22 to +104 °F) 40 to 90 % RH +5 °C (+41 °F) pre-set Contact maker (NO) 01012.0-21 DC 13 A -30 to +50 °C (-22 to +122 °F) 40 to 90 % RH +5 °C (+41 °F) pre-set Contact maker (NO) 01012.0-22 DC 11 A -30 to +60 °C (-22 to +140 °F) 40 to 90 % RH +5 °C (+41 °F) pre-set Contact maker (NO) V ersions with secondary switching function can also register the temperature and therefore offer an additional protection for electronics. Switch difference: 3 K (±1 K tolerance) at +25 °C (+77 °F), 50 % RH. 30.11.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. ELECTRONIC HYGROSTAT DCF 010 | DC 20 to 56 V www.stego.de | www.stego.co.uk | www.stegonorden.se 8585 REGULATING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET
01012.0-21 价格&库存
很抱歉,暂时无法提供与“01012.0-21”相匹配的价格&库存,您可以联系我们找货
