ST 011 Compact Thumbwheel Thermostat
Adjustable thumbwheel setting
Compact design
Small hysteresis
High switching capacity
The ST 011 thermostat is an SPST regulator with a small hysteresis. The housing design
ensures optimized air circulation around the sensor element.
STO 011: NC / opens on temperature rise (red thumbwheel) - for regulating heaters or for
switching signal devices when temperature has fallen below the minimum value.
Convenient minimum setpoint symbol on the NC
thermostat to assure
enclosure temperature
remains above freezing
Regulating
DIN rail mountable
STS 011: NO / closes on temperature rise (blue thumbwheel) - for regulating filter fans, heat
exchangers, cooling devices or for switching signal devices when temperature limit has been
exceeded.
Technical Data
Switching difference
7°F (4K) ± 5.4°F (3K) tolerance
Sensor element
thermostatic bimetal
Contact type
snap-action contact
Service life
> 100,000 cycles
Max. switching capacity
15A resistive / 2A inductive @ 120VAC
10A resistive / 2A inductive @ 250VAC
DC 30 W (24-72VDC)
Max. inrush current
AC 16A for 10 sec.
Connection
2-pole terminal for AWG 14 max. (2.5mm²), torque 1Nm max.
Housing
plastic, UL 94V-0, light grey
Mounting
clip for 35mm DIN rail, EN 60 715
Mounting position
vertical
Operating / Storage temperature
-49 to +176°F (-45 to +80°C)
Max. storage humidity
90% RH (non-condensing)
Dimensions
2.76 x 1.3 x 1.65” (70 x 33 x 42mm)
Weight
approx. 1.8 oz. (50g)
Protection type
IP20
ST 011 Thermostat
NC (red)
Heater
ST 011 Thermostat
e.g. Filter Fan
ST 011 Thermostat
e.g. Signal Device
NO (blue)
Enclosure heater
Wiring example
Part No. (NC)
01115.9-00
01115.0-00
Part No. (NO)
01116.9-00
01116.0-00
Setting range
32 to 140°F
0 to 60°C
Approvals
UL and VDE submitted
Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application.
STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
ST011/2-11/US
Filter fan, cooling equipment, signal device
很抱歉,暂时无法提供与“01116.9-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+135.951081+17.67320
- 5+127.345485+16.55450
- 10+119.5222110+15.53750
- 25+114.3936225+14.87080
