01925.1-01
01925.1-01
    STEGO
    STEGO - 01925.1-01 - Enclosure Cooling, IP20, SJ 019 Series, Plastic, 60 mm, 50 mm, 132 mm
01925.1-01 数据手册
65 65 STEGOJET SJ 019 >>Prevents heat pockets >>Wide voltage range >>Compact design >>Quick connection >>Clip or screw fixing The STEGOJET is a compact, powerful built-in-fan. It allows precise cooling of heat sources and the air flow prevents formation of heat pockets. Its design offers a maximum rotation range with an air output in almost any direction. On one hand the dual clip system (two clips in a 90° angle) allows four different positions on a DIN rail, while on the other hand the hinge in the housing can be moved in a 40° angle. The airflow at the air outlet can also be directed in a 45° angle and the air duct can be rotated in steps of 60°. TECHNICAL DATA Axial fan, ball bearing air flow 27.6 m³/h, free flow service life 40,000 h at +60 °C (+140 °F), 90 % RH Power consumption 4W Connection 2-pole dual pressure clamp for rigid wire 2.5 mm², stranded wire (with wire end ferrule) 1.5 mm² Casing plastic according UL94 V-0, black Mounting clip for 35 mm DIN rail, EN 60715 or screw fixing (M5), torque 2 Nm max., washers have to be used Fitting position variable Dimensions 132 x 75 x 60 mm Weight approx. 0.2 kg Operating/Storage temperature -10 to +60 °C (+14 to +140 °F)/-30 to +70 °C (-22 to +158 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type IP20 Range of rotation: Art. No. Model Operating voltage Protection class 01925.0-00 Clip fixing AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) II (double insulated) VDE UL File No. E234324 Approvals EAC 01925.0-01 Screw fixing AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) II (double insulated) VDE UL File No. E234324 EAC 01925.1-00 Clip fixing DC 24 V (min. DC 12 V, max. DC 26.4 V) III (double insulated) VDE – EAC 01925.1-01 Screw fixing DC 24 V (min. DC 12 V, max. DC 26.4 V) III (double insulated) VDE – EAC 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. www.stego.de | www.stego.co.uk | www.stegonorden.se COOLING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET
01925.1-01 价格&库存
很抱歉,暂时无法提供与“01925.1-01”相匹配的价格&库存,您可以联系我们找货
