02034.0-10
02034.0-10
    STEGO
    STEGO - 02034.0-10 - Heater, 230 V, 200 W, 240 mm, 60 mm, 120 mm, 9.45 "
02034.0-10 数据手册
HAZARDOUS AREA HEATER CREx 020 | 50 W to 250 W (T3) >>For areas with explosion hazard >>Large convection surface >>Clip and screw flange fixing >>Ready-to-use with strain relief >>Maintenance free >>Temperature class T3 www.stego.de | www.stego.co.uk | www.stegonorden.se 41 41 HEATING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET Photo Art. No. 02033.0-00 TECHNICAL DATA Temperature class Ex Protection type Gases Dusts D 25 II 2 GD Ex db IIC T3 Gb Ex tb IIIC T200°C Db IP66 Ambient temperature -60 to +85 °C (-76 to +185 °F) Surface temperature max. +200 °C (+392 °F) Heating element high performance cartridge Heating body aluminium profile, silver anodised Connection silicone cable (halogen-free) 3 x 0.75 mm², length 1 m Connection PE 0.75 to 2.5 mm² Mounting clip for 35 mm DIN rail, EN 60715 for heating body sizes 80 x 48 mm and 120 x 60 mm; screw fixing with 2 plug-on flanges for all heating body sizes, optional widthwise mounting Fitting position vertical airflow (connection on bottom) Storage temperature -60 to +85 °C (-76 to +185 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP66 / I (earthed) Approvals EPS 16 ATEX 1 109 X IECEx EPS 16.0048X EAC X H W T3 CREx 020 with screw flange fixing CREx 020 with clip fixing Clip fixing Screw flange fixing Operating voltage Heating capacity Rec. pre-fuse T (time-delayed) Dimensions (D x W x H) Weight approx. Art. No. Art. No. Hole spacing X 02031.0-00 02031.0-10 150 mm AC 230 V 50 W 0.5 A 80 x 48 x 110 mm 0.7 kg 02031.9-00 02031.9-10 150 mm AC 120 V 50 W 1.0 A 80 x 48 x 110 mm 0.7 kg 02032.0-00 02032.0-10 225 mm AC 230 V 100 W 1.0 A 80 x 48 x 180 mm 1.0 kg 02032.9-00 02032.9-10 225 mm AC 120 V 100 W 2.0 A 80 x 48 x 180 mm 1.0 kg 02033.0-00 02033.0-10 225 mm AC 230 V 150 W 1.5 A 120 x 60 x 180 mm 1.4 kg 02033.9-00 02033.9-10 225 mm AC 120 V 150 W 3.0 A 120 x 60 x 180 mm 1.4 kg 02034.0-00 02034.0-10 300 mm AC 230 V 200 W 2.0 A 120 x 60 x 240 mm 1.7 kg 02034.9-00 02034.9-10 300 mm AC 120 V 200 W 4.0 A 120 x 60 x 240 mm 1.7 kg - 02035.0-10 275 mm AC 230 V 250 W 2.5 A 160 x 80 x 220 mm 2.3 kg - 02035.9-10 275 mm AC 120 V 250 W 5.0 A 160 x 80 x 220 mm 2.3 kg 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Compact convection heater of temperature class T3 (200 °C max.) for use in areas with explosion hazard for prevention of formation of condensation, temperature fluctuations, and for protection against frost in control and switch cabinets, as well as in measuring equipment.
02034.0-10 价格&库存
很抱歉,暂时无法提供与“02034.0-10”相匹配的价格&库存,您可以联系我们找货
