28401.0-02
28401.0-02
    STEGO
    STEGO - 28401.0-02 - VENT PLUG, STAINLESS STEEL, ENCLOSURE
28401.0-02 数据手册
101101 PRESSURE COMPENSATION DEVICE (STAINLESS STEEL) DA 284 | IP66 >>High degree of protection >>Waterproof membrane >>Corrosion resistant >>Food safe Pressure differentials in enclosures with a high degree of protection are a result of internal and external temperature changes. In the case of negative pressure or partical vacuum, dust and humidity can enter the enclosure through the door seal. When the air inside the enclosure cools down, condensation may occur because the humidity cannot escape the enclosure. The easy-to-install pressure compensation device DA 284 provides compensation of pressure at a protection degree of IP66. Even with a slight overpressure, a waterproof membrane inside the plug allows the humidity to escape whilst blocking water and dirt from entering the enclosure. Photo: Inside view TECHNICAL DATA Mounting thread M40 x 1.5 with nut Torque 5 Nm Depth in enclosure approx. 9 mm Sealing sealing gasket NBR Filter waterproof membrane Air permeability 1,200 l/h at a pressure difference of min. 70mbar Dimensions Ø 58 x 31 mm Fitting position variable Operating/Storage temperature -45 to +80 °C (-49 to +176 °F) Approvals EAC Installation: Make cut-out Ø 40.5+0,5 mm in enclosure wall and mount pressure compensation device with nut. Please make sure that the sealing gasket is put in place on the outer side panel of the enclosure. For optimal pressure compensation we recommend to use two devices on opposite sides towards the top of the enclosure. 1 Art. No. Stainless steel Protection type 1 packaging unit Weight (approx.) 28401.0-00 V2A (DIN 1.4301 / AISI 304)1 IP66 (EN 60529) / IPX9K (EN 40050-9) 1 piece 0.2 kg 28401.0-02 V4A (DIN 1.4404 / AISI 316L) IP66 (EN 60529) / IPX9K (EN 40050-9) 1 piece 0.2 kg V2A is not sea waterproof 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. www.stego.de | www.stego.co.uk | www.stegonorden.se ACCESSORIES STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET
28401.0-02 价格&库存
很抱歉,暂时无法提供与“28401.0-02”相匹配的价格&库存,您可以联系我们找货
  • 1+1862.17110
库存:4
