01161.0-02
    STEGO
01161.0-02 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com TAMPERPROOF THERMOSTAT FTO 011 / FTS 011 >>Compact design >>Fixed set point >>Color coded modules >>DIN rail mountable TECHNICAL DATA Sensor element thermostatic bimetal Contact type snap-action contact Service life > 100,000 cycles Max. switching capacity 10 A resistive / 2 A inductive @ AC 120 V 5 A resistive / 1.6 A inductive @ AC 250 V DC 30 W Max. inrush current AC 16 A for 10 sec. Connection 2-pole terminal, clamping torque 0.8 Nm max.: solid/stranded1 wire - AWG 14 max. (2.5 mm²) Housing plastic, UL 94V-0, light grey Mounting clip for 35 mm DIN rail, EN 60715 Mounting position vertical Operating / Storage temperature -40 to +176 °F (-40 to +80 °C) / -49 to +176 °F (-45 to +80 °C) Operating / Storage humidity max. 95 %RH (non-condensing) Dimensions 1.85 x 1.3 x 1.3” (47 x 33 x 33 mm) Weight approx. 0.8 oz. (23 g) Protection type IP20 Approvals UL File No. E164102, VDE, EAC (Eurasian Conformity) ¹ When connecting with stranded wires, wire end ferrules must be used. Heater NC (red) NO (blue) Enclosure heater Thermostat FTO 011 Thermostat FTS 011 e.g. Fan Thermostat FTS 011 e.g. Signal Device Wiring examples Filter fan, cooling equipment, signal device Part No. Contact Switch-off temperature Switch-on temperature 01160.0-00 NC - open on rise 59 °F / 15 °C (± 9 °F / 5 K tolerance) 41 °F / 5 °C (± 9 °F / 5 K tolerance) 01160.0-01 NC - open on rise 77 °F / 25 °C (± 9 °F / 5 K tolerance) 59 °F / 15 °C (± 9 °F / 5 K tolerance) Part No. Contact Switch-on temperature Switch-off temperature 01161.0-00 NO - close on rise 122 °F / 50 °C (± 11 °F / 6 K tolerance) 104 °F / 40 °C (± 12.6 °F / 7 K tolerance) 01161.0-01 NO - close on rise 140 °F / 60 °C (± 11 °F / 6 K tolerance) 122 °F / 50 °C (± 12.6 °F / 7 K tolerance) 01161.0-02 NO - close on rise 95 °F / 35 °C (± 11 °F / 6 K tolerance) 77 °F / 25 °C (± 12.6 °F / 7 K tolerance) Note: Other switch-off and switch-on temperatures on request. 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Tamperproof (Pre-set) Thermostat NC (normally closed): Thermostat opens on temperature rise (red module housing) – for regulating heaters or for switching signal devices when temperature has fallen below the minimum value. Tamperproof (Pre-set) Thermostat NO (normally open): Thermostat closes on temperature rise (blue module housing) – for regulating filter fans, heat exchangers, cooling devices or for switching signal devices when temperature limit has been exceeded.
01161.0-02
物料型号:FTO 011(常闭型,红色模块外壳)和FTS 011(常开型,蓝色模块外壳)。
器件简介: - 紧凑设计。 - 固定设定点。 - 模块颜色编码。 - 可安装在DIN轨道上。
引脚分配:2极接线端子,建议使用0.8Nm的最大拧紧扭矩,适用于最大AWG14(约2.5mm²)的单股或多股电线。
参数特性: - 传感元件:双金属片恒温传感器。 - 接触类型:快动式接触。 - 使用寿命:超过10万次。 - 最大切换容量:10A阻性/2A感性@AC 120V;1.6A感性@AC 250V,DC 30W。 - 最大浪涌电流:AC 16A,持续10秒。 - 外壳材料:塑料,UL 94V-0,浅灰色。 - 安装方式:适用于35mm DIN轨道,符合EN 60715标准。 - 安装位置:垂直。 - 工作/存储温度:-40至+176°F(-40至+80°C)/ -49至+176°F(-45至+80°C)。 - 工作/存储湿度:最高95%RH(不凝结)。 - 尺寸:1.85x1.3x1.3英寸(约47x33x33mm)。 - 重量:约0.8盎司(23克)。 - 保护类型:IP20。 - 认证:UL File No.E164102,VDE,EAC(欧亚合格标志)。
功能详解: - 防篡改(预设)恒温器NC:温度上升时恒温器打开,用于调节加热器或当温度降至最低值以下时切换信号设备。 - 防篡改(预设)恒温器NO:温度上升时恒温器关闭,用于调节过滤器风扇、热交换器、冷却设备或当温度超过限制时切换信号设备。
应用信息:适用于加热器、恒温器、风扇、信号设备等。
封装信息:尺寸、重量、保护类型和认证信息。
01161.0-02 价格&库存
很抱歉,暂时无法提供与“01161.0-02”相匹配的价格&库存,您可以联系我们找货
  • 1+108.605411+13.57130
  • 5+102.094515+12.75770
  • 10+96.9400510+12.11360
  • 25+91.1525925+11.39040
库存:208
01161.0-02
    • 1+90.82949
    库存:8
