01231.0-01
01231.0-01
    STEGO
01231.0-01 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com >>Efficient temperature & humidity control >>Wide voltage range www.stegousa.com ELECTRONIC HYGROTHERM WITH EXTERNAL SENSOR ETF 012 >> Operating temperature down to -40 °C >>High switching capacity >>With external sensor TECHNICAL DATA Switching difference (temperature) 2 K (±1 K tolerance) at +25 °C (+77 °F), 50 %RH Switching difference (humidity) 4 %RH (±1 % tolerance) at +25 °C (+77 °F), 50 %RH Reaction time (humidity) approx. 5 sec. Contact type change-over contact (relay) Service life VDE: NO/NC > 15,000 cycles UL: NO/NC > 30,000 cycles Max. switching capacity (relay output) 10 A resistive / 1.6 A inductive @ AC 240 V 0.6 A @ DC 60 V¹ Max. inrush current AC 30 A for 10 sec. Connection 5-pole terminal, clamping torque 0.5 Nm max.: solid/stranded² wire - AWG 14 max. (2.5 mm²) Housing plastic, UL 94V-0, light grey Mounting clip for 35 mm DIN rail, EN 60715 Mounting position vertical Operating/Storage temperature -40 to +140 °F (-40 to +60 °C) Operating/Storage humidity max. 95 %RH (non-condensing) Dimensions 3.0 x 2.4 x 1.7" (77 x 60 x 43 mm) Weight approx. 3.5 oz. (100 g) Protection type IP20 Approvals UL File No. E164102, VDE, GOST-R not UL confirmed ² When connecting with stranded wires, wire end ferrules must be used. 1 Hygrotherm ETF 012 Heater Heater Wiring example Part No. Cable – 1 m Part no. Cable – 2 m Operating voltage Setting range – temperature Setting range – humidity 01231.0-00 01231.0-01 AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) 0 to +60 °C 50 to 90 %RH 01231.9-00 01231.9-01 AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) +32 to +140 °F 50 to 90 %RH 01231.1-00 01231.1-01 DC 24-48 V (min. DC 20 V, max. DC 60 V) 0 to +60 °C 50 to 90 %RH 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The ETF 012 senses the ambient temperature and relative humidity in an enclosure. Depending on which contact combination is chosen, it then turns on or off a connected device if either the temperature is below or the humidity is above the set point.  The integrated LED in each adjustment knob i lit when indicating the active function. The external sensor can be positioned freely anywhere in the enclosure for precise measurements.
01231.0-01 价格&库存
很抱歉,暂时无法提供与“01231.0-01”相匹配的价格&库存,您可以联系我们找货
