01351.0-00
01351.0-00
    STEGO
    STEGO - 01351.0-00 - DOOR SWITCH, NC, ENCLOSURE/CABINET
01351.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com DOOR SWITCH DS 013 >>Tool-free adjustable switch positioning >>Strain relief, suitable for range of cable diameters >>High switching capacity >>Suitable for lamp LED 025 and other devices TECHNICAL DATA Max. switching capacity 10 A resistive / 1.5 A inductive @ AC 250 V Service life VDE: > 10,000 cycles UL: > 6,000 cycles Connection 4-pole clamp with strain relief, clamping torque 0.5 Nm max. Housing plastic according to UL 94V-0, grey/black Mounting M5 screws (not included) Mounting position variable Operating / Storage temperature -4 to +185 °F (-20 to +85 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Dimensions 3.4 x 2.5 x 1.2" (87 x 64 x 30 mm) Weight approx. 1.8 oz. (50 g) Protection type IP20 Approvals UL + VDE intended Wiring diagrams Part No. Model Suitable wire 01350.0-00 change-over (CO) Round cable, stranded wire (with wire end ferrule) AWG 18 to 17 (0.75 mm² to 1 mm²) 01351.0-00 normally closed (NC) Round cable, stranded wire (with wire end ferrule) AWG 18 to 16 (0.75 mm² to 1.5 mm²) 01352.0-00 normally open (NO) Round cable, stranded wire (with wire end ferrule) AWG 18 to 16 (0.75 mm² to 1.5 mm²) 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The door switch monitors the position of cabinet doors and is available in three versions. For example, it can be used for switching a light when opening a door (NC), or to activate a fan when closing a door (NO). The version with change-over contact (CO) can be used as a normally closed and/or normally open contact. The wide mechanical adjustment range of the door switch DS 013 offers versatile mounting: the housing is adjustable within a 1-3/8" (35 mm) range, while the screw flange with a slotted hole offers an additional 13/16" (21 mm). The travel of the switch itself is another 5/16" (8 mm).
01351.0-00
物料型号:DS 013
器件简介: - 门开关可监控机柜门的位置,有三种版本。 - 可用于开门时切换灯光(常闭NC),或关门时激活风扇(常开NO)。 - 带转换触点(CO)的版本可用作常闭或常开接触。
引脚分配: - 4极插座,带有防拉脱设计,最大夹紧扭矩0.5Nm。
参数特性: - 最大切换容量:10A电阻性/1.5A感性@交流250V。 - 服务寿命:VDE认证超过10,000次循环,UL认证超过6,000次循环。 - 工作/存储温度:-4至+185华氏度(-20至+85摄氏度)。 - 工作/存储湿度:最大90%RH(无冷凝)。 - 尺寸:3.4x2.5x1英寸(87x64x30毫米)。 - 重量:约1.8盎司(50克)。 - 保护类型:IP20。 - 认证:UL+VDE。
功能详解: - 无需工具即可调整开关位置。 - 适合多种电缆直径的拉力释放。 - 高切换容量。 - 适用于LED025灯具和其他设备。
应用信息: - 门开关的机械调整范围广泛,可提供多功能安装。 - 外壳可调节范围为1-3/8英寸(35毫米),螺丝法兰带槽孔提供额外的13/16英寸(21毫米)。 - 开关本身的行程为5/16英寸(8毫米)。
封装信息: - 外壳材质:根据UL 94V-0标准的塑料,颜色为灰黑色。 - 安装方式:使用M5螺丝(不包括)。 - 安装位置:可变。
接线图: - CO(转换触点)、NO(常开)、NC(常闭)。
型号和适用线缆: - 01350.0-00:转换触点(CO),适用线缆为圆形电缆,绞合线(带线端套),AWG18到17(0.75mm²到1mm²)。 - 01351.0-00:常闭(NC),适用线缆为圆形电缆,绞合线(带线端套),AWG18到15(0.75mm²到1.5mm²)。 - 01352.0-00:常开(NO),适用线缆为圆形电缆,绞合线(带线端套),AWG18到1(0.75mm²到15mm²)。
01351.0-00 价格&库存
很抱歉,暂时无法提供与“01351.0-00”相匹配的价格&库存,您可以联系我们找货
