Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
LED 021
Movement sensor and
screw fixing
LED 022
On/off switch
and magnet fixing
www.stegousa.com
VARIOLINE LAMP
LED 021/022
>>High luminous flux
>>Integrated power unit
>>Durable and maintenance-free
LED technology
>>Daisy chain
>>On/off switch or movement sensor
>>Magnet or screw fixing
TECHNICAL DATA
LED 021/022
side view
L1
L2
1.72in
LED 021/022
magnet or
screw fixing
Power consumption
max. 11 W/16 W
Operating voltage
AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V)
Luminous flux
1,080 Lm/1,730 Lm
Lamp type
LED, angle of radiation 120°
light color: daylight, color temperature: 6,500 K
Service life
60,000 h at +20 °C (+68 °F)
Connection
2-pole connector with snap lock
AC: max. 2.5 A / AC 240 V, color: white
Mounting
magnet fixing or screw fixing (M5), torque 2 Nm max.
Casing
plastic, translucent
Dimensions
see drawings
Weight
approx. 0.2 kg/0.3 kg
Operating/Storage temperature
-30 to +40 °C (-22 to +104 °F) / -40 to +85 °C (-40 to +185 °F)
Operating/Storage humidity
max. 90 % RH (non-condensing)
Protection type/Protection class
IP20 / II (double insulated)
Mounting options: The lamps are available with magnet fixing for easy positioning in any steel cabinet or enclosure. A classic
is the LED 021/022 with screw fixing. With a total rotation angle of 360° it provides perfect illumination.
Note: The lamp must not be used for household lighting.
View of magnet fixing
View of screw fixing
1.72in
LED 021 (Size 1)
L1 = 15.6 in
L2 = 14.6 in
LED 022 (Size 2)
L1 = 23.4 in
L2 = 22.4 in
Size 1: L1 = 400 mm
Size 2: L1 = 600 mm
Art. No.
Magnet fixing
Art. No.
Screw fixing
Art. No.
Magnet fixing
Art. No.
Screw fixing
02100.0-30
02100.0-00
02200.0-30
02200.0-00
On/off switch
VDE
UL
02110.0-30
02110.0-00
02210.0-30
02210.0-00
PIR movement sensor1
VDE
UL
02120.0-30
02120.0-00
02220.0-30
02220.0-00
without switching option
VDE
UL
¹ approx. 5 min. fixed switch-on duration
Switch
Approvals
15.02.2019 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The LED 021/022 Varioline is a powerful and compact LED lamp for use in enclosures. Its LED tube emits more
than 1,000/1,700 Lm at only 11 W/16 W power consumption, thereby illuminating even very large enclosures in
their full depth and height. The glare-free, 360° rotatable LED tube uses Mid-power LEDs with a service life of
60,000 h. The emitted daylight color of 6,500 K provides safety for the user by a natural and non-fading color
reproduction.
www.stegousa.com
ACCESSORIES LED 021/022
Connectors and cables for electrical connection are not included in the delivery of the LED 021/022. These parts can be ordered separately.
Sets, consisting of lamp and accessories, are available on request. Likewise, custom cables are available on request.
LAMP-SET WITH FEMALE CONNECTOR
Varioline LED enclosure lamps are also available as a set including the connector Art. No. 264057.
Simply add -0003 to the article number of the required lamp. For example: 02100.0-30-0003
FEMALE / MALE CONNECTORS
1
Photo: Male connector, Art. No. 264058
Art. No.
Model
Voltage type
Color
Use for
Wire cross-section1
Approvals
264057
female connector
AC
white
power input
0,5-2,5 mm2 (AWG 14-20)
VDE + UL
264058
male connector
AC
white
power output
VDE + UL
applies to rigid and stranded wire. Wire end ferrules must be used when connecting with stranded wires
CONNECTION CABLE WITH FEMALE CONNECTOR AND OPEN END
Photo: Connection cable, Art. No. 244356
1
Art. No.
Model
Length
Voltage type
Color
Use for
244356
connection cable 2 x 1.5 mm² with female connector
2.0 m
AC
connector: white; cable: white
power input
Approvals²
VDE
244357
connection cable 2 x AWG 16 with female connector
2.0 m
AC
power input
VDE + UL
Approvals²
² applies only to the individual components (cable and connectors)
EXTENSION CABLE WITH 2 CONNECTORS FOR DAISY CHAIN CONNECTION
Photo: Extension cable, Art. No. 244358
2
Art. No.
Model
Length
Voltage type
Color
Use for
244358
extension cable 2 x 1.5 mm² with 2 connectors
1.0 m
AC
connectors: white; cable: white
daisy chain
VDE
244359
extension cable 2 x AWG 16 with 2 connectors
1.0 m
AC
daisy chain
VDE + UL
CONNECTION EXAMPLE
2
1
0.75in
0.75in
0.75in
This illustration shows the LED 021/022 lamp in a daisy chain application. The lamps are conveniently connected via connection plugs - up to 8 lamps max. can be daisy-chained this way.
The snap lock connectors ensure a stable electrical connection even if subjected to heavy vibration. The connection example shows a AC 230 V application, using the following cables:
connection cable with female connector, Art. No. 244356 (1); daisy chain extension cable with 2 connectors, Art. No. 244358 (2).
Female/male connectors are also available to assemble cables in non-standard lengths.
Photo: Female connector, Art. No. 264057
很抱歉,暂时无法提供与“02100.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+920.332161+118.05110
