03103.9-00
03103.9-00
    STEGO
03103.9-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com FAN HEATER HVL 031 | 100 - 400 W >>Compact size >>Flat design >>Built-in overheat protection >>3-side DIN rail mountable The compact HVL 031 high-performance fan heater prevents formation of condensation and provides an evenly distributed interior air temperature in enclosures. For large OEM use, this fan heater can also be provided without the fan, in which case the OEM/customer must provide a fan which meets the minimum airflow requirements. TECHNICAL DATA 100 W/ 150 W Heater 200 W/ 300 W/ 400 W Heater Heating element high performance cartridge Overheat protection built-in temperature limiter Heater body die-cast aluminum, glass bead finish Axial fan, ball bearing service life 50,000 h at 77 °F (25 °C) Air flow, free blowing see table below Axial fan connection 2-pole terminal AWG 14 max. (2.5 mm²), terminals L2/N2 Connection 3-pole terminal AWG 14 max. (2.5 mm²), torque 0.8 Nm max. Connection housing plastic, UL 94V-0, black Mounting clip for 35 mm DIN rail, EN 60715 Mounting position horizontal Operating / Storage temperature -49 to +158 °F (-45 to +70 °C) Protection class / Protection type I (grounded) / IP20 Approvals UL File No. E187294 (all), GOST TR (all), VDE (AC 230 V only) Important! Heater must be be operated together with a fan. Operating without a fan creates the danger of overheating. Part No. - AC 120 V Part No. - AC 230 V Heating capacity Min. airflow (free blowing) Dimensions (as mounted) 03102.9-00 03102.0-00 100 W 20 cfm (35 m³/h) 1.85 x 3.15 x 4.41” (47 x 80 x 112 mm) Weight (approx.) 1.3 lbs. (600 g) 03103.9-00 03103.0-00 150 W 20 cfm (35 m³/h) 1.85 x 3.15 x 4.41” (47 x 80 x 112 mm) 1.3 lbs. (600 g) 03113.9-00 03113.0-00 200 W 63 cfm (108 m³/h) 1.85 x 4.68 x 5.94” (47 x 119 x 151 mm) 2.0 lbs. (900 g) 03114.9-00 03114.0-00 300 W 63 cfm (108 m³/h) 1.85 x 4.68 x 5.94” (47 x 119 x 151 mm) 2.0 lbs. (900 g) 03115.9-00 03115.0-00 400 W 63 cfm (108 m³/h) 1.85 x 4.68 x 5.94” (47 x 119 x 151 mm) 2.0 lbs. (900 g) 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Shown: 100 W - HVL 031 Fan Heater
03103.9-00 价格&库存
很抱歉,暂时无法提供与“03103.9-00”相匹配的价格&库存,您可以联系我们找货
