06101.9-00
06101.9-00
    STEGO
    STEGO - 06101.9-00 - FLAT HEATER, 120V, 100W
06101.9-00 数据手册
19 HEATING PRODUCT CATALOG - STEGO, Inc. Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com FLAT HEATER CP 061 | 50 W, 100 W > Screw fixing > Linear expansion compensation > Integrated temperature cut-out > Ready-to-use with strain relief The Flat Heater CP 061 is used to provide an evenly distributed temperature within enclosures and cabinets with electric/electronic components. Its ultra-thin design makes it particularly suitable for high-density applications for which standard enclosure heaters are often too big in size. Depending on the application, the Flat Heater can be used as a convection heater or as a contact heater. When used as a contact heater it offers thermoconductive contact to a component or a cabinet wall in need to be heated. Additionally, a mounting system especially designed for the CP 061 allows for the compensation of an expansion of the heater body as a result of the heating-up when in operation. Operated as a convection heater, the slim heater CP 061 warms up the ambient air within a cabinet. The CP 061 is designed for permanent operation. TECHNICAL DATA 4" (100 mm) Heating element resistance heater Overheat protection with automatic reset Heater body aluminum profile Surface temperature max. +302 °F (+150 °C) at +77 °F (+25 °C) Connection silicone cable (halogen-free) 3 x AWG 18 (0.75 mm²), length 3 ft (1 m) Connection casing plastic, UL 94V-0, black Mounting screw mount M6 (not included) Fitting position horizontal, variable connection or vertical, connection on bottom Dimensions L x 4" x .32" (L x 100 x 8 mm) Storage temperature -40 to +185 °F (-40 to +85 °C) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP30 / I (grounded) 40" ( 1000 mm) 2.4" (60 mm) L 0.32" (8 mm) X 3" (75 mm) 0.26" (6,5 mm) 3.3" (84 mm) Wiring example Part No. Operating voltage Heating capacity Length (L) Hole spacing (X) Weight approx. Operating temperature 06100.0-00 AC 230 V, 50/60 Hz 50 W 9.41" (239 mm) 8.9" (225 mm) .88 lbs (0.4 kg) -40 to +140 °F (-40 to +60 °C) VDE Approvals EAC 06101.0-00 AC 230 V, 50/60 Hz 100 W 16.3" (414 mm) 15.75" (400 mm) 1.54 lbs (0.7 kg) -40 to +140 °F (-40 to +60 °C) VDE EAC 06100.9-00 AC 120 V, 50/60 Hz 50 W 9.41" (239 mm) 8.9" (225 mm) .88 lbs (0.4 kg) -40 to +104 °F (-40 to +40 °C) UL EAC 06101.9-00 AC 120 V, 50/60 Hz 100 W 16.3" (414 mm) 15.75" (400 mm) 1.54 lbs (0.7 kg) -40 to +104 °F (-40 to +40 °C) UL EAC 01.07.2020 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. > Contact/Convection heater > Ultra flat design > Compact > Easy, firm installation
06101.9-00 价格&库存
很抱歉,暂时无法提供与“06101.9-00”相匹配的价格&库存,您可以联系我们找货
