264059
    STEGO
264059 数据手册
90TECHNICAL 90 LIGHTING DATASHEET LAMP LED 025 >>Wide voltage range >>Integrated power unit >>Long-lived and maintenance-free by LED technology LED 025 with on/off switch and magnet fixing >>Daisy chain >>On/off switch or movement sensor >>Magnet, screw or clip fixing The lamp series LED 025 is suitable for all types of panels and enclosures, especially where space is at a premium. The lamps have a very long service life thanks to the use of LED technology. Three different fixing options provide more flexibility for installation. The power output allows up to 10 lamps to be connected to each other (DC 12 V versions up to 5 lamps). Both the power input and output connectors snap lock into their sockets. With the integrated power unit and the plugs the lamp can quickly be connected. TECHNICAL DATA LED 025 with on/off switch and clip fixing LED 025 with movement sensor and screw fixing LED 025 with clip fixing LED 025 with magnet or screw fixing Power consumption max. 5 W Luminosity 400 Lm at 120° (1,200 Lm at 360° or equivalent 95 W light bulb) Lamp type LED, angle of radiation 120° light color: daylight, color temperature: 6,000 K to 7,000 K Service life 60,000 h at +20 °C (+68 °F) Connection 2-pole connector with snap lock AC: max. 2.5 A / AC 240 V, color: white DC: max. 2.5 A / DC 60 V, color: blue Mounting magnet fixing or screw fixing (M5), clip fixing (M6), torque 2 Nm max. Casing plastic, transparent Dimensions see drawings Weight 0.2 kg Operating/Storage temperature -30 to +60 °C (-22 to +140 °F) / -40 to +85 °C (-40 to +185 °F) Operating/Storage humidty max. 90 % RH (non-condensing) Protection type/Protection class IP20 / II (double insulated), DC 12 V: IP20 / III (extra-low voltage) Mounting options: The lamps are available with magnet fixing for easy positioning in any steel cabinet or enclosure. A classic is the LED 025 with screw fixing. The clip holders exclusively designed for clip fixing of the LED 025 can be positioned anywhere in the cabinet by simply screwing the holders to the cabinet wall. The lamp is snapped into the clip holders and can be turned 351 250 in both directions. With a total rotation angle of 180° it provides perfect illumination within the cabinet or enclosure. Note: The lamp must not be used for household lighting. 32 32 41 9,75 52 52 32 47,3 32 9,75 39 34 32 Side view clip fixing 36 32 Side view screw fixing 42 Side view magnet fixing 40 40 Art. No. Magnet fixing Art. No. Screw fixing Art. No. Clip fixing Operating voltage Switch 02540.0-00 02540.0-01 02540.0-03 AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) on/off light switch VDE UL File No. E234324 EAC 02540.1-00 02540.1-01 02540.1-03 DC 24 – 48 V (min. DC 20 V, max. DC 60 V) on/off light switch VDE UL File No. E234324 EAC 02540.2-00 02540.2-01 02540.2-03 DC 12 V (min. DC 10 V, max. DC 16 V) on/off light switch – UL File No. E234324 EAC 02541.0-00 02541.0-01 02541.0-03 AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) PIR movement sensor¹ VDE UL File No. E234324 EAC 02541.1-00 02541.1-01 02541.1-03 DC 24 – 48 V (min. DC 20 V, max. DC 60 V) PIR movement sensor¹ VDE UL File No. E234324 EAC ¹ approx. 5 min. fixed switch-on duration Appovals 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUCT CATALOGUE - STEGO Connectors and cables for electrical connection are not included in the delivery of the LED 025. These parts can be ordered separately. Sets, consisting of lamp and accessories, are available on request. CONNECTION CABLE WITH FEMALE CONNECTOR AND OPEN END Photo: Connection cable, Art. No. 244356 1 Art. No. Model Length Voltage type Color Use for 244356 connection cable 2 x 1.5 mm² with female connector 2.0 m AC connector: white; cable: white power input Approvals² VDE 244357 connection cable 2 x AWG 15 with female connector 2.0 m AC connector: white; cable: white power input VDE + UL 244360 connection cable 2 x 0.75 mm² with female connector 2.0 m DC 24 – 48 V connector: blue; cable: white power input VDE 244361 connection cable 2 x AWG 15 with female connector 2.0 m DC 24 – 48 V connector: blue; cable: white power input VDE + UL 244389 connection cable 2 x 0.75 mm² with female connector 2.0 m DC 12 VD connector: blue; cable: white power input VDE 244390 connection cable 2 x AWG 15 with female connector 2.0 m DC 12 V connector: blue; cable: white power input VDE + UL Approvals² ² applies only to the individual components (cable and connectors) EXTENSION CABLE WITH 2 CONNECTORS FOR DAISY CHAIN CONNECTION Photo: Extension cable, Art. No. 244358 2 Art. No. Model Length Voltage type Color Use for 244358 extension cable 2 x 1.5 mm² with 2 connectors 1.0 m AC connectors: white; cable: white daisy chain VDE 244359 extension cable 2 x AWG 15 with 2 connectors 1.0 m AC connectors: white; cable: white daisy chain VDE + UL 244362 extension cable 2 x 1.5 mm² with 2 connectors 1.0 m DC 24 – 48 V connectors: blue; cable: white daisy chain VDE 244363 extension cable 2 x AWG 15 with 2 connectors 1.0 m DC 24 – 48 V connectors: blue; cable: white daisy chain VDE + UL 244391 extension cable 2 x 1.5 mm² with 2 connectors 1.0 m DC 12 V connectors: blue; cable: white daisy chain VDE 244392 extension cable 2 x AWG 15 with 2 connectors 1.0 m DC 12 V connectors: blue; cable: white daisy chain VDE + UL ² applies only to the individual components (cable and connectors) FEMALE / MALE CONNECTORS Photo: Female connector, Art. No. 264057 Photo: Male connector, Art. No. 264058 Art. No. Model Voltage type Color Use for Approvals 264057 female connector AC white power input VDE + UL 264058 male connector AC white power output VDE + UL 264059 female connector DC 24 – 48 V blue power input VDE + UL 264060 male connector DC 24 – 48 V blue power output VDE + UL 264065 female connector DC 12 V blue power input VDE + UL 264066 male connector DC 12 V blue power output VDE + UL CONNECTION EXAMPLE 1 2 This illustration shows the LED 025 lamp in a daisy chain application. The lamps are conveniently connected via quick connection plugs – up to 10 (5) lamps max. can be daisy-chained this way. The snap lock connectors ensure a stable electrical connection even if subjected to heavy vibration. The connection example shows a AC 230 V application, using the following cables: connection cable with female connector, Art. No. 244356 (1); daisy chain extension cable with 2 connectors, Art. No. 244358 (2). Female/male connectors are also available to assemble cables in non-standard lengths. 04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. ACCESSORIES www.stego.de | www.stego.co.uk | www.stegonorden.se 91 91 LIGHTING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET
264059 价格&库存
很抱歉,暂时无法提供与“264059”相匹配的价格&库存,您可以联系我们找货
    • 1+56.789511+7.09640
    • 3+51.002043+6.37320
    • 10+44.4007210+5.54830
    库存:10
