FZK 011 Mechanical Thermostat
Wide adjustment range
High switching capacity
SPDT (change-over) contact
Very low hysteresis option
The FZK 011 mechanical thermostat is used for controlling heating and cooling equipment, filter fans or signal devices where a higher degree of sensing accuracy is required. An integrated
resistor (RF) can be connected to improve the switch temperature difference (see Option note).
The thermostat registers the surrounding air and can switch both inductive and resistive loads
via snap-action contact.
Regulating
DIN rail mountable
Technical Data
Switching difference
approx. 9°F (5K), tolerance -5.4/+3.6°F (-3/+2K)
Option note:
connecting terminal “N” (RF heating resistor) enables thermal
feedback, reducing the hysteresis - amount is subject to
1.5” (38 mm)
surrounding conditions TBD for each individual application
1.97” (50 mm)
Sensor element
thermostatic bimetal
Contact type
SPDT / change-over contact
Contact resistance
< 10m˜
Service life
> 100,000 cycles
Max. switching capacity, NC
10A resistive / 4A inductive @ 120VAC
10A resistive / 4A inductive @ 250VAC
DC 30W
Max. switching capacity, NO
5A resistive / 2A inductive @ 120VAC
2.64” (67 mm)
5A resistive / 2A inductive @ 250VAC
DC 30W
Minimum load
20mA (all voltages)
Connection
4-pole terminal, clamping torque 0.5Nm max.:
solid wire - AWG 14 max. (2.5mm²)
stranded wire (with wire end ferrule) - AWG 16 max. (1.5mm²)
Housing
plastic, UL 94V-0, light grey
Mounting
clip for 35mm DIN rail, EN 60 715
Mounting position
vertical
Operating / storage temperature
-49 to +149°F (-45 to +65°C)
Dimensions
2.64 x 1.97 x 1.5” (67 x 50 x 38mm)
Weight
approx. 3.5 oz. (100g)
Protection type
IP20
FZK 011 Thermostat
Heater
FZK 011 Thermostat e.g. Filter Fan
FZK 011 Thermostat e.g. Signal Device
Enclosure heater
Filter fan, cooling equipment,
signal device
Part No.
01170.0-00
01170.0-01
01170.9-00
01170.9-01
Operating
230VAC
230VAC
120VAC
120VAC
Setting range
5 to 60°C
40 to 140°F
40 to 140°F
5 to 60°C
Approvals
UL File No. E164102
UL File No. E164102
UL File No. E164102
UL File No. E164102
1) Voltage only needs to be specified if the optional use of the RF resistor is desired.
Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application.
STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
FZK011/2-11/US
Wiring examples
voltage1)
很抱歉,暂时无法提供与“01170.9-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+371.844671+46.46560
- 5+349.960815+43.73100
- 10+328.1673910+41.00770
- 25+306.2835425+38.27310
