Dual
Thermostat
ZR 011
Actual size
shown with °C scale
Two thermostats in one unit
- one Normally Closed (NC)
& one Normally Open (NO)
- or two Normally Open (NO)
Each with wide adjustable
temperature range
Available with °F or °C scale
DIN rail mountable
The ZR 011 houses two separate thermostats, allowing the
independent control of heating and cooling or other
equipment. Both thermostats offer wide adjustment ranges
and are color coded for easy function recognition.
Technical Data ZR 011
Part No.
01172.0-01
01175.0-01
01172.0-00
01175.0-00
NC (red)
32 - 140°F
14 - 122°F
0 - 60°C
-10 - 50°C
NO (blue)
32 - 140°F
68 - 176°F
0 - 60°C
20 - 80°C
01176.0-00
01176.0-01
NO (blue)
0 - 60°C
32-140°F
NO (blue)
0 - 60°C
32-140°F
Sensor element:
Maximum tolerance:
Switching difference (hysteresis):
Thermostatic bi-metal
± 7.2°F (4K)
12.6°F ± 5.4°F (7°C ± 4°C)
Switching capacity (max. Load):
EMI/EMC compliance:
Connections:
Mounting:
Dimensions (H x W x D):
Housing:
Weight:
Protection type:
Operating/storage temperature:
Agency approvals:
Patent pending
NC: 10A resistive/2A inductive @ 250 VAC
NO: 5A resistive/2A inductive @ 250 VAC
DC 30 W
EN55014-1 u. 2, EN61000-3-2/A14, EN61000-3-3
2
4-pole terminal for AWG 14 max. (2.5 mm )
Clip for 35mm DIN rail (EN 50022)
2.6 x 2.0 x 1.8” (67 x 50 x 46 mm)
Plastic, UL94V-O
3.2 oz (90 g)
IP 20
-49 to 158°F (-45 to 70°C)
UL, CSA
NO (normally open)
- contact will close at
temperature rise
很抱歉,暂时无法提供与“01172.0-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+321.656491+40.19410
- 5+304.565385+38.05840
- 10+287.4742710+35.92270
- 25+270.3831625+33.78700
