80TECHNICAL
80
REGULATING
DATASHEET
>>Temperature and humidity adjustable
>>Wide voltage range
>>Operating temperature down to -40 °C
>>High switching capacity
>>Status indicator (LED)
The electronic hygrotherm senses the ambient temperature and relative humidity in an enclosure with electric/
electronic components and turns on a heater (or alternatively a fan) at either set point, helping prevent the formation of condensation in the enclosure. Due to its wide voltage range the hygrotherm can be utilised anywhere
in the world. The LED integrated in the adjustment knob on the active controller is lit when the connected
device is in operation.
TECHNICAL DATA
Connection diagram
Switch difference (temperature)
2 K (±1 K tolerance) at +25 °C (+77 °F), 50 % RH
Switch difference (humidity)
4 % RH (±1 % tolerance) at +25 °C (+77 °F), 50 % RH
Reaction time (humidity)
approx. 5 sec.
Contact type
change-over contact (relay)
Service life
VDE: NO/NC > 15,000 cycles
UL: NO/NC > 30,000 cycles
Max. switching capacity (relay output)
AC 240 V, 10 (1.6) A
DC 60 V, 0.6 A¹
Max. inrush current
AC 30 A for 10 sec.
Optical indicator
LED
Connection
5-pole terminal, clamping torque 0.5 Nm max.:
rigid/stranded² wire 2.5 mm² (AWG 14)
Mounting
clip for 35mm DIN rail, EN 60715
Casing
plastic according to UL94 V-0, light grey
Dimensions
77 x 60 x 43 mm
Weight
approx. 0.2 kg
Fitting position
vertical
Operating/Storage temperature
-40 to +60 °C (-40 to +140 °F)
Operating/Storage humidity
max. 90 % RH (non-condensing)
Protection type
IP20
Approvals
VDE, UL File No. E164102, EAC
¹ not UL confirmed
² When connecting with stranded wires, wire end ferrules must be used.
Hygrotherm
ETF 012
Heater
Heater
L
N
N
L
Example of connection
Art. No.
Operating voltage
Setting range temperature
Setting range humidity
01230.0-00
AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V)
0 to +60 °C
50 to 90 % RH
01230.9-00
+32 to +140 °F
50 to 90 % RH
01230.1-00
DC 24 – 48 V (min. DC 20 V, max. DC 60 V)
0 to +60 °C
50 to 90 % RH
04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
ELECTRONIC HYGROTHERM
ETF 012
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUCT CATALOGUE - STEGO
很抱歉,暂时无法提供与“012309-00”相匹配的价格&库存,您可以联系我们找货
