01883.9-00
01883.9-00
    STEGO
    STEGO - 01883.9-00 - FILTER FAN, BALL, 115VAC, 81W, IP54
01883.9-00 数据手册
1 TECHNICAL 1 DATASHEET FILTER FAN PLUS FPI/FPO | 223 x 223 mm >>New air-flap outlet technology for high airflow >>Easy mounting >>Protection type test/Environmental rating by independent testing institutes (VDE and UL) >>Two systems for optimal airflow (FPI/FPO) >>Standard enclosure cut-out sizes (5 sizes) >>One filter mat Filter fans are used to provide an optimum climate in enclosures and cabinets with electrical/electronic components. The interior temperature of an enclosure can be reduced by channelling cooler filtered outside air into the enclosure thus expelling heated internal air. The resulting airflow prevents formation of localised hot pockets in installations and protects electronic components from overheating. The Filter Fan Plus series uses a new air-flap outlet technology for the air outlet and thus reaches a high degree of airflow. A ratchet mechanism is used for mounting and provides high stability and tightness. Depending on the application there are two systems that are available – the FPI or FPO system. The FPI system is a standard installation with a filter fan in the lower part of the enclosure which ensures that fresh air is fed into the enclosure (airflow direction "In"). This system consists of a filter fan and exit filter. Whereas in the FPO system, the filter fan is located in the upper area of the enclosure to avoid heat buildups (airflow direction "Out"). The FPO system is composed of an intake filter and exit filter fan. The Filter Fan Plus series has been designed for indoor use. TECHNICAL DATA SYSTEM FPI Axial fan, ball bearing service life L10 at +40 °C (+104 °F): min. 56,000 h rotor metal Connection 3-pole clamp for 2.5 mm², clamping torque 0.8 Nm max. Casing, hood, flaps plastic according to UL94 V-0, light grey; UV light resistant according to UL746C (f1) Enclosure cut-out 223 x 223 mm Mounting frame 4 built-in ratchet braces for mounting (6 notches for wall thickness 1 — 4 mm). Additional use of screws possible if needed1. Filter mat G3 acc. to DIN EN 779, average arrestance Aa 84 % Filter material synthetic fibre with progressive construction, temperature resistant to +100 °C, self-extinguishing class F1, moisture resistant to 100 % RH, reusable Operating temperature -25 to +65 °C (-13 to +149 °F) Storage temperature -40 to +70 °C (-40 to +158 °F) Operating/Storage humidity max. 75 % RH (non-condensing) Protection type/Protection class IP54 / I (earthed) Environmental rating UL/NEMA UL TYPE 12 / NEMA 12 Approvals VDE, UL File No. E234324, EAC Note other voltages on request warm Air outlet through flaps cold Air intake through filter mat with fan 1 Drilling marks for screw mounting are indicated on mounting frame. AIRFLOW DIRECTION "IN": FILTER FAN FPI 018 Art. No. Operating voltage Air volume, free flow 01873.0-30 AC 230 V, 50/60 Hz 305 m³/h 01873.9-30 AC 115 V, 50/60 Hz 332 m³/h Air volume with exit filter Current consumption (50/60 Hz) Power consumption Average noise level (DIN EN ISO 4871) Depth in enclosure Weight (approx.) Filter mat 227 m³/h 300/340 mA 64 W 64 dB 147 mm 2.4 kg G3 238 m³/h 600/700 mA 81 W 67 dB 147 mm 2.4 kg G3 AIRFLOW DIRECTION "IN": EXIT FILTER FPI 118 Art. No. Depth in enclosure Weight (approx.) Air outlet 11873.0-00 46 mm 0.6 kg air-flap outlet technology 15.10.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUKTKATALOG - STEGO 2 TECHNICAL 2 DATASHEET www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUKTKATALOG - STEGO SYSTEM FPO warm Air outlet through flaps with fan AIRFLOW DIRECTION "OUT": FILTER FAN FPO 018 Art. No. Operating voltage Air volume, free flow 01883.0-00 AC 230 V, 50/60 Hz 536 m³/h 01883.9-00 AC 115 V, 50/60 Hz 581 m³/h Air volume with exit filter Current consumption (50/60 Hz) Power consumption Average noise level (DIN EN ISO 4871) Depth in enclosure Weight (approx.) air outlet 281 m³/h 300/340 mA 310 m³/h 600/700 mA 64 W 65 dB 147 mm 2.4 kg air-flaps 81 W 68 dB 147 mm 2.4 kg air-flaps AIRFLOW DIRECTION "OUT": INTAKE FILTER FPO 118 Art. No. Depth in enclosure Weight (approx.) Filter mat 11883.0-30 25 mm 0.5 kg G3 acc. to DIN EN 779, average arrestance Aa 84 % FILTER MAT FM 086 Filter class 215 x 215 mm Average arrestance Aa 1 packing unit G3 acc. to DIN EN 779 Art. No. 08636.0-00 84 % 5 pieces TECHNICAL DRAWINGS 46 25 26 FPI 018 257 147 FPI 118 26 26 223 26 223 223 147 223 257 FPO 018 FPO 118 15.10.2015 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. cold Air intake through filter mat
01883.9-00
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压可达5000V。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
01883.9-00 价格&库存
很抱歉,暂时无法提供与“01883.9-00”相匹配的价格&库存,您可以联系我们找货
  • 1+1817.95395
  • 5+1766.95739
  • 12+1713.21158
  • 25+1672.53513
  • 50+1636.17001
库存:6
