2
LIGHTING
PRODUCT CATALOG - STEGO, Inc.
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
ECOLINE LIGHT
LED 025
>>Energy saving LED technology
>>Wide voltage range
>>Integrated power unit
LED 025 Light
with clip mount
>>Magnet, screw or clip mount
>>Wide variety of connections
>>Dual cage clamp for quick wiring
LED 025 Light
with motion sensor
and screw mount
On/off switch light
w/magnet or screw
mount
TECHNICAL DATA
LED 025 Light
with on/off switch
and magnet mount
On/off switch light
w/clip mount
Ecoline Light
LED 025
top view
Power consumption
max. 5 W (~ 75 W incandescent bulb)
Luminosity
400 Lm at 120° (1,200 Lm at 360° or equivalent 95 W light bulb)
Lamp type
LED, 120° angle of radiation
light color – daylight, color temperature – 6,000 to 7,000 K
Service life
60,000 hrs. at 68°F (20°C)
Connection
2-pole dual cage clamp for solid wire AWG 14 (2.5 mm2),
and stranded wire (wire end ferrule) AWG 16 (1.5 mm2)
Housing
plastic, transparent
Mounting
magnet, M5 screws (not included), or clip (M6 screws),
torque 2 Nm max.
Operating / Storage temperature
-22 to +140 °F (-30 to +60 °C ) / -40 to +185 °F (-40 to +85 °C)
Operating / Storage humidity
max. 90 % RH (non-condensing)
Dimensions
see drawings
Weight
approx. 7 oz. (200 g)
Protection type / Protection class
IP20 / II (double insulated)
Mounting options: The lights are available with magnet mount for easy positioning in any steel cabinet or enclosure. Other options
are the LED 025 with screw mount, and specifically designed clip holders for clip mount of the LED 025. These can be positioned
anywhere in the cabinet by simply screwing the holders to the cabinet wall. The light is snapped into the clip holders and can be
turned in both directions. With a total rotation angle of 180° it provides perfect illumination within the cabinet or enclosure.
Magnet mount end view
Part No. –
magnet mount
Part No. –
screw mount
Part No. –
clip mount
02540.3-10
02540.3-11
02541.3-10
Screw mount end view
Clip mount end view
Operating voltage
Switch type
Approvals
02540.3-13
AC 100 – 240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V)
DC 90 – 110 V (min. DC 80 V, max. DC 125 V)
on/off switch
UL File No. E234324
VDE (REG.-Nr. E788)1
EAC
02541.3-11
02541.3-13
PIR motion sensor2
UL File No. E234324
EAC
02542.3-10
02542.3-11
02542.3-13
N/A
UL File No. E234324
EAC
02540.1-10
02540.1-11
02540.1-13
DC 24 – 48 V (min. DC 20 V, max. DC 60 V)
on/off light switch
UL File No. E234324
EAC
02541.1-10
02541.1-11
02541.1-13
PIR motion sensor2
UL File No. E234324
EAC
02542.1-10
02542.1-11
02542.1-13
N/A
UL File No. E234324
EAC
VDE Certificate of Conformity (REG.-Nr. E788); Passive Infrared (PIR) motion sensor is factory pre-set to turn the light off 5 minutes after all motion ceases
Note: The lights are not approved for household lighting.
1
2
01.08.2017 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The LED 025 light series is suitable for all types of panels and enclosures, especially where space is at a premium.
These lights have a very long service life due to the use of LED technology. They are available with powerful non-slip
rubberized magnets allowing them to be easily positioned in any steel enclosure. Screw and clip mounting are
also available as options. The Ecoline series is a simplified version of the standard LED 025 light and has a dual
cage clamp for connection instead of connectors. Nonetheless it is suitable for daisy-chaining and allows for up
to 10 lights to be connected to each other.
很抱歉,暂时无法提供与“02540.1-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+753.323481+97.46250
- 3+674.017083+87.20210
- 10+594.7980210+76.95300
