02700.0-00
02700.0-00
    STEGO
02700.0-00 数据手册
23 www.stego.de | www.stego.co.uk | www.stegonorden.se HEATING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET SEMICONDUCTOR FAN HEATER CR 027 | up to 650W >>Compact heater >>Integrated thermostat >>Clip fixing >>Optical indicator >>Temperature safety cut-out TECHNICAL DATA Heating element PTC resistor - temperature limiting Temperature safety cut-out to protect against overheating in case of fan failure, automatic reset Axial fan, ball bearing airflow see table service life 50,000h at +25°C (+77°F) Connection 2-pole clamp 2.5mm², clamping torque 0.8Nm max Casing plastic according to UL94 V-0, light grey Optical indicator thermostat control lamp Mounting clip for 35mm DIN rail, EN 60715 Fitting position vertical airflow (air outlet up) – other fitting positions possible Dimensions 100 x 128 x 165mm Operating/Storage temperature -45 to +70°C (-49 to +158°F) Operating/Storage humidity max. 90% RH (non-condensing) Protection type/Protection class IP20 / II (double insulated) Approvals VDE, UL File No. E204590 Heating capacity (W) Heating capacity / Ambient temperature diagram CR 027 (60Hz) Heating capacity (W) Heating capacity / Ambient temperature diagram CR 027 (50Hz) Temperature (°C) Art. No. Operating voltage Heating capacity¹ (50 Hz) 02700.0-00 220-240VAC, 50/60Hz 475W 02701.0-00 220-240VAC, 50/60Hz 550W 02700.9-00 100-120VAC, 50/60Hz 400W 02701.9-00 100-120VAC, 50/60Hz 510W ¹ at +20°C (+68°F) ambient temperature ² Switch temperature difference 7K (±4K tolerance) Temperature (°C) Heatig capacity¹ (60 Hz) Inrush current max. Pre-fuse T (time-delay) Airflow, free flow Setting range thermostat² Weight (approx.) 550W 11A 650W 13A 6.3A 35m³/h 0 to +60°C 0.9kg 8A 45m³/h 0 to +60°C 550W 1.1kg 14A 8A 35m³/h +32 to +140°F 0.9kg 650W 15A 8A 45m³/h +32 to +140°F 1.1kg 20.03.2013 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Semiconductor fan heater prevents formation of condensation and frost and provides an evenly distributed interior air temperature in enclosures with electric/electronic components. The integrated thermostat is used to set the desired temperature.
02700.0-00 价格&库存
很抱歉,暂时无法提供与“02700.0-00”相匹配的价格&库存,您可以联系我们找货
    • 1+4312.21176
    • 25+4251.25572
    • 50+4203.99053
    • 100+4187.78429
    • 500+3446.53774
    库存:76
    02700.0-00
    • 1+1645.607841+212.90330
    • 10+1527.3469810+197.60310
    • 25+1442.3633525+186.60820
    • 50+1359.9126550+175.94100
    库存:25
