Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
TOUCH-SAFE PTC FAN HEATER
CS 028 / CSL 028 | 150 - 400 W
>>Compact size
>>Quiet operation
>>DIN rail or screw mount available
>>Heating power adjusts to ambient
temperature
The CS 028 / CSL 028 fan heater prevents formation of condensation and provides an evenly distributed interior
air temperature in enclosures. The heater is connected using the internal terminal connectors. The surface
temperatures on the accessible side surfaces of the housing are minimized as a result of the heater design.
The small size of the CS 028 / CSL 028 make it ideal for use in enclosures where space is at a premium.
TECHNICAL DATA
View: back side
Screw mount
PTC resistor - temperature limiting
Surface temperature
150 W / 250 W: max. 122 °F (50 °C) except upper protective grill
400 W: max. 149 °F (65 °C) except upper protective grill
measured at 68 °F (20 °C) ambient temperature
Axial fan, ball bearing
service life 40,000 h at 104 °F (40 °C)
Air flow, free blowing
CS 028: 8 cfm (13.8 m³/h)
CSL 028: 32 cfm (54 m³/h) @ AC 120 V;
26 cfm (45 m³/h) @ AC 230 V
Connection
2-pole terminal AWG 14 max. (2.5 mm²) with strain relief,
torque 0.8 Nm max.
Housing
plastic, UL 94V-0, black
Mounting
screw mount or clip for 35 mm DIN rail, EN 60715
Mounting position
vertical
Operating / Storage temperature
-49 to +158 °F (-45 to +70 °C)
Operating / Storage humidity
max. 90 %RH (non-condensing)
Protection class / Protection type
II (double insulated) / IP20
Approvals
UL File No. E234324 (all), GOST TR (all), VDE (AC 230 V only)
Note
other voltages available upon request
Heating Power (W)
DIN clip
Heating element
Wiring example
CS(L) 028
Fan Heater
Thermostat
Ambient Temperature
Part No. - DIN mount
Part No. - screw
mount
Series
Operating voltage
Heating
capacity¹
Max. current
(inrush)
Dimensions
(H x W x D)
Weight
(approx.)
02800.0-00
02800.0-01
CS 028
AC 230 V, 50/60 Hz
150 W
12 A
2.95 x 2.56 x 3.54” (75 x 65 x 90 mm)
10.6 oz. (300 g)
02800.9-00
02800.9-01
CS 028
AC 120 V, 50/60 Hz
150 W
6A
10.6 oz. (300 g)
02810.0-00
02810.0-01
CSL 028
AC 230 V, 50/60 Hz
400 W
15 A
3.54 x 3.35 x 4.37” (90 x 85 x 111 mm)
17.6 oz. (500 g)
02810.9-00
02810.9-01
CSL 028
AC 120 V, 50/60 Hz
400 W
9A
17.6 oz. (500 g)
02811.0-00
02811.0-01
CSL 028
AC 230 V, 50/60 Hz
250 W
9A
17.6 oz. (500 g)
02811.9-00
02811.9-01
CSL 028
AC 120 V, 50/60 Hz
250 W
6A
17.6 oz. (500 g)
¹ at 68 °F (20 °C) ambient temperature
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
Photo: Fan Heater CSL 028
很抱歉,暂时无法提供与“02810.9-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2180.15762
- 25+2092.95215
- 50+2005.73626
- 国内价格 香港价格
- 1+1000.960271+125.07970
- 2+938.473722+117.27140
