70
ACCESSORIES
TECHNICAL
DATASHEET
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUCT CATALOGUE - STEGO
ELECTRICAL SOCKET
SD 035
>>Quickly connected
>>Available with or without fuse
>>Clip fixing
TECHNICAL DATA
Connection
3 x pressure clamps for stranded and rigid wire 0.5 - 2.5mm²
Mounting
clip for 35mm DIN rail, EN 60715
Casing
plastic according to UL94 V-0, light grey
Dimensions
92 x 62 x 48mm
Weight
approx. 0.2kg
Fitting position
variable
Operating/Storage temperature
-45 to +70°C (-49 to +158°F)
Operating/Storage humidity
max. 90% RH (non-condensing)
Protection type/Protection class
IP20 / I (earthed)
Connections from mains
Art. No.
Operating voltage max.
Socket
Model
Nominal current
Approvals
03500.0-00
250VAC
Germany/Russia (1)
with fuse¹
6.3A
03500.0-01
250VAC
Germany/Russia (1)
without fuse
16.0A
03501.0-00
250VAC
F/PL/CZ/SK (2)
with fuse¹
6.3A
03501.0-01
250VAC
F/PL/CZ/SK (2)
without fuse
16.0A
03502.0-00
250VAC
Switzerland (3)
with fuse¹
6.3A
03502.0-01
250VAC
Switzerland (3)
without fuse
10.0A
03503.0-00
250VAC
UK/Irland (4)
with fuse¹
6.3A
03503.0-01
250VAC
UK/Irland (4)
without fuse
13.0A
03504.0-00
125VAC
USA/Canada (5)
with fuse¹
6.3A
UL File No. E222026
03504.0-01
125VAC
USA/Canada (5)
without fuse
15.0A
UL File No. E222026
03505.0-00
250VAC
Italy (6)
with fuse¹
6.3A
03505.0-01
250VAC
Italy (6)
without fuse
16.0A
03507.0-01
240VAC
Australia (7)
without fuse
10.0A
03508.0-01
250VAC
Brazil (8)
without fuse
10.0A
¹ fuse Ø 5 x 20mm
20.03.2013 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The DIN rail mounted electrical socket can be quickly fitted and connected in enclosures allowing the use of auxiliary
products such as hand lamps, measuring devices, soldering irons etc. The unit is available with and without fuse
and in many world socket standards.
很抱歉,暂时无法提供与“03503.0-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+221.728821+28.72460
- 5+202.102945+26.18210
- 10+182.6515110+23.66220
