CSK 060 Touch-Safe PTC Heater 10 & 20W
Low surface temperature
Compact size
Wide voltage range
Double insulated protection
The CSK 060 is a touch-safe heater for use in enclosures. The design of the heater utilizes natural convection which results in a circulating current of warm air. The surface temperatures on
the accessible side surfaces of the housing are minimized as a result of the heater design.
Heating
DIN rail mountable
Technical Data
Heating capacity
see table
Heating element
PTC resistor - temperature limiting
Surface temperature
< 176°F (80°C), except upper protective grill
Connection
4-pole terminal AWG 14 max (2.5mm²), torque 0.8Nm max.
Mounting
clip for 35mm DIN rail, EN 60 715
Housing
plastic, UL 94V-0, black
Mounting position
vertical
Operating / storage temperature
-49 to +158°F (-45 to +70°C)
Protection class
II (double insulated)
Protection type
IP20
Approvals
UL File No. E150057, VDE
Note
other voltages available upon request
Thermostat
CSK 060 Heater
Part No.
06030.0-00
06040.0-00
06040.1-00
Heating capacity1)
20W
10W
10W
Operating voltage2)
AC/DC 120-240V
AC/DC 120-240V
AC/DC 12-30V
Max. current (inrush)
2.5A
1.0A
8A
Dimensions
3.86 x 2.95 x 1.5” (98 x 75 x 38mm)
Weight (approx.)
6.1 oz. (170g)
5.0 oz. (140g)
5.0 oz. (140g)
68°F (20°C) ambient temperature
operating high voltage heaters below AC/DC 140V reduces heating performance by approx. 10% (min. 110V, max 265V).
1) at
2)
Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application.
STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
CSK060/12-09/US
Wiring example
很抱歉,暂时无法提供与“06040.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+224.987731+28.11440
- 3+210.971213+26.36290
- 10+195.5982610+24.44190
