07200.2-00
07200.2-00
    STEGO
    STEGO - 07200.2-00 - SENSOR DISTRIBUTION BOX, M12-4P, 3PORT
07200.2-00 数据手册
1 1 www.stego-connect.com www.stego.de STEGO - PRODUKTKATALOG TECHNICAL DATASHEET ACTUATOR HUB AHC 072 | IO-Link, DC 24 V, 3 Relais Outputs > Digital IO-Link interface > Small size > Easy DIN rail or screw mounting > M12 plug-in connector The IO-Link Actuator Hub AHC 072 can switch up to three actuators or loads on process level via relays. Switching commands for the loads are received via the IO-Link interface from a higher-level control unit: edge computer, cloud, PLC control, etc. The actuator hub supports both AC and DC loads, independent of their function or whether they have a communication interface. This means that analog devices, such as heaters or filter fans, can easily be integrated into a digital network. The actuator hub combined with other products of the STEGO CONNECT product family can be built into a powerful IO-Link IIoT system. Please visit our website on www.stego-connect.com for further information. A universal mounting bracket is included for ideal positioning of the actuator hub on DIN rail or with screws within an application. TECHNICAL DATA Universal mounting bracket for DIN rail and screw mounting 1 to 3 contact makers (NO), with 3 optical indicators Max. switching capacity AC 240 V, 10 A DC 30 V, 10 A Max. inrush current AC 16 A for 10 sec. Actuator connection 2-pole Push-In terminals (3 x) IO-Link connection M12 round plug connector, IEC 61076-2-101, 4-pin, A-coded Electrical protection Reverse-polarity, short circuit, overvoltage protection Mounting clip for 35 mm DIN rail, EN 60715 and screw mounting (M5) Casing plastic according to UL94 V-0, light grey Dimensions 107 x 35 x 108 mm (116 mm with universal mounting bracket) Weight approx. 160 g Fitting position variable Operating temperature1 -40 to +70 °C (-40 to +158 °F) with 3 outputs with 2 A load each1 -40 to +40 °C (-40 to +104 °F) with 3 outputs with 10 A load each1 Storage temperature -40 to +85 °C (-40 to +185 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Operating altitude ≤ 4,000 m above sea leavel Protection type/Protection class IP40 / III (SELV) Certificates CB No. DE1-63389 in conformity with IEC 61010-1 evaluated according to UL and CSA standards The max. operating temperature depends on the current (see diagram) and the number of loads. Ambient temperature Ta [°C] 1 Number of relay outputs Load current IL [A] Example of connection Current in relation to temperature with 3 active relays Art. No. Interface Operating voltage Power consumption max. 07200.2-00 IO-Link (digital, specified acc. to version 1.1) DC 24 V (DC 18-30 V) 1.4 W ² stranded wire with wire end ferrule Push-In terminals wire cross sections² 1.5 mm² (VDE) AWG 18 (UL) 17.11.2020 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. > for 1 to 3 actuators > Quick connection for actuators via Push-In terminals > Optical indicators (LEDs)
07200.2-00 价格&库存
很抱歉,暂时无法提供与“07200.2-00”相匹配的价格&库存,您可以联系我们找货
