08613.0-01
08613.0-01
    STEGO
08613.0-01 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com ROOF FILTER FAN RFP 018 | 177 - 338 CFM >>Very low noise >>Minimal mounting depth >>High air volume Photo: Part No. 01860.0-00 >>High reliability >>Time-saving installation and mat exchange Photo: Part No. 01861.0-00 TECHNICAL DATA Axial fans, ball bearing service life min. 50,000 h at 77 °F (25 °C) and 65 %RH aluminum fan body, plastic rotor Connection 3-pole clamp, AWG 14 (2.5 mm²), clamping torque 0.8 Nm max. Housing plastic, UL 94V-0, light grey; UV light resistant according to UL 746C (f1) Filter mat G3 acc. to DIN EN 779, filtering degree 85% Filter material synthetic fiber with progressive construction, temperature resistant to 212 °F, self-extinguishing class F1; moisture resistant to 100 %RH, reusable - can be cleaned by washing or vacuuming Operating / Storage temperature dependent on fan type (see below) Operating / Storage humidity max. 90 %RH (non-condensing) Protection class / Protection type I (grounded) / IP32 Approvals GOST TR (all), VDE (AC 230 V only); UL intended Roof Filter Fan RFP 018 - 177 cfm (01860.0-xx) Hole centers Important note: For reasons of pressure compensation, the roof filter fan must always be operated in combination with another filter fan (e.g. Part No. 01803.0-00) or a passive intake filter (e.g. Part No. 11803.0-00). Roof Filter Fan RFP 018 - 338 cfm (01861.0-xx) Use included template for precise cut-out dimensions Enclosure cut out Part No. Operating voltage Air volume, free blowing Power consumption Average noise level (DIN EN ISO 4871) Mounting depth Enclosure cut-out Weight (approx.) Operating / Storage temperature 01860.0-00 AC 230 V, 50 Hz¹ 177 cfm (300 m³/h) - 4 fans 68 W 55 db (A) 2.0” (52 mm) 9.8 x 9.8” 7.3 lbs. (3.3 kg) +14 to +158 °F (-10 to +70 °C) / -40 to +158 °F (-40 to +70 °C) 01860.0-02 AC 120 V, 60 Hz 203 cfm (345 m³/h) - 4 fans 60 W 55 db (A) 2.0” (52 mm) 9.8 x 9.8” 7.3 lbs. (3.3 kg) -13 to +158 °F (-25 to +70 °C) 01861.0-00 AC 230 V, 50 Hz¹ 294 cfm (500 m³/h) - 1 fan 64 W 67 db (A) 4.2” (107 mm) 9.8 x 9.8” 5.7 lbs. (2.6 kg) +14 to +158 °F (-10 to +70 °C) / -40 to +158 °F (-40 to +70 °C) 01861.0-02 AC 120 V, 60 Hz 338 cfm (575 m³/h) - 1 fan 85 W 67 db (A) 4.2” (107 mm) 9.8 x 9.8” 5.7 lbs. (2.6 kg) -13 to +158 °F (-25 to +70 °C) ROOF EXHAUST FILTER REP 118 Part. No. Mounting depth Enclosure cut-out Weight (approx.) Filter mat Protection type 11860.0-00 0.43” (11 mm) 9.8 x 9.8” 2.2 lbs. (1.0 kg) G3 acc. to DIN EN 779, filtering degree 85% IP32 FILTER MAT FM 086 Filter mat 11.1 x 11.1” (282 x 282 mm) G3 (1 packing unit = 3 pcs.) Part No. 08613.0-00 ¹ air volume increases by 15% when operating AC 230 V filter fans at 60 Hz 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. Roof filter fans and roof exhaust filters are used in enclosures from which warm air must be diverted due to increased heat development. The ready-to-connect and low-noise roof filter fan is used to expel warm air from within the enclosure. Alternatively, the roof exhaust filter provides passive ventilation. The RFP 018 series comes in two versions: one utilizes four small axial fans, improving reliability and maintaining continuous operations even if one of the fans should fail; the second uses a larger single high capacity fan.
08613.0-01 价格&库存
很抱歉,暂时无法提供与“08613.0-01”相匹配的价格&库存,您可以联系我们找货
