09550.0-05
09550.0-05
    STEGO
    STEGO - 09550.0-05 - SCREW MOUNTING, CABINET/ENCLOSURE
09550.0-05 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com MOUNTING AID STEGOFIX PLUS SFP 095 >>Alternative to 35 mm DIN rail >>Simple installation >>For small, DIN rail mountable devices Optional: > Screw mounting > Self-adhesive tape mounting > Or Magnet mounting TECHNICAL DATA Applications For devices designed for DIN rail mounting on 35 mm DIN rail (according to EN 60715), max. clip width 66 mm (2.6”) Mounting Self-adhesive tape mounting Intitial adhesive power is 40% and 1.1 lbs after 24hrs > Screw mounting e.g. self-tapping screws DIN 7981 (ISO 7049), Ø 5.5 mm; thread-forming screws DIN 7500, M5; (not included in delivery) > Self-adhesive tape mounting adhesive surface 2.6 x 1” (65 x 25 mm) > Magnet mounting 2 neodymium magnets, rubberized Material plastic, UL94V-0, black Dimensions 2.8 x 1.6 x 0.6” (71 x 40 x 15 mm) Operating temperature -31 to +167 °F (-35 to +75 °C) Storage conditions (self-adhesive tape) optimal storage conditions for self-adhesive tape approx. +68 °F (+20 °C) at 50 % RH Approvals EAC 1.58“ (40mm) 0.98“ (25mm) Installation notes: The self-adhesive mounting option can only be maintained on smooth surfaces, e.g. metals, lacquered surfaces and plastics (except, polyethylene, polypropylene and rubber). The surfaces must be dry & free from dust, oil separating agents & other contamination. Magnet mounting 5x Ø 0.22“ (Ø 55 mm) 0.98“ (25m m 1.97“ (50m ) m) 2.6“ (6 6mm ) 2.8“ (71m m) Application example “ 59 ) m m 1( 5 0. Part No. Model Max. Holding force1 1 packing unit Weight (approx.) 09550.0-05 Screw mounting - 5 pieces 2.3 oz. (65 g) total / 0.46 oz. (13 g) per piece 09550.1-05 Self-adhesive tape mounting 75 N 5 pieces 2.5 oz. (70 g) total / 0.49 oz. (14 g) per piece 09550.2-05 Magnet mounting 30 N 5 pieces 5.1 oz. (145 g) total / 1.0 oz. (29 g) per piece ¹ At room temperature. Depending on the conditions of use (e.g. surface condition, size of device to be mounted, etc.) the actual holding force may differ from the values specified in the table above. 03.09.2018 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. STEGOFIX PLUS allows for a quick and easy direct mounting of smaller devices where DIN Rails may be inconvenient, i.e. in cabinets and enclosures. It is suitable for devices with a DIN clip of 66 mm/2.6” width max., replacing the conventional 35 mm/1.4” DIN rail. STEGOFIX PLUS is available in three different mounting versions – for screw mounting with 25 mm/98” pitch, with high-performance adhesive tape or rubberized neodymium magnets – offering the right mounting method for almost any application. Screw mounting
09550.0-05 价格&库存
很抱歉,暂时无法提供与“09550.0-05”相匹配的价格&库存,您可以联系我们找货
