Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
PANEL-MOUNT PTC FAN HEATER
CS 130 | 1200 W
>>Compact design
>>Built-in overheat protection
>>Integrated adjustable thermostat
(optional)
>>Double insulated plastic housing
>>Panel or DIN rail mounting
TECHNICAL DATA
Heating element
PTC resistor - temperature limiting
Overheat protection
built-in temperature limiter
Axial fan, ball bearing
service life 50,000 h at 77 °F (25 °C)
Air flow, free blowing
94 cfm (160 m³/h)
Connection
2-pole terminal AWG 16 max. (1.5 mm²) with strain relief,
clamping torque 0.8 Nm max.
Housing
plastic, UL 94V-0, black
Mounting
clip for 35 mm DIN rail, EN 60715 or M6 screws (not included)
Mounting position
horizontal
Operating / Storage temperature
-49 to +158 °F (-45 to +70 °C)
Operating / Storage humidity
max. 90 %RH (non-condensing)
Dimensions
4.7 x 6.3 x 7.2” (120 x 160 x 182 mm)
Weight
approx. 2.6 lbs. (1.2 kg)
Protection class / Protection type
II (double insulated) / IP20
Heating Power (W)
Wiring diagram
Ambient Temperature
Part No.
Heating capacity¹
Operating voltage
Max. current (inrush)
Setting range2
13060.0-00
1200 W
AC 230 V, 50/60 Hz
13.0 A
0 to 60 °C
UL File No. E234324
VDE
GOST TR
13060.0-01
1200 W
AC 230 V, 50/60 Hz
13.0 A
none (no integrated controls)
UL File No. E234324
VDE
GOST TR
13060.9-00
1200 W
AC 120 V, 50/60 Hz
16.0 A
32 to 140 °F
UL File No. E234324
GOST TR
13060.9-01
1200 W
AC 120 V, 50/60 Hz
16.0 A
UL File No. E234324
GOST TR
¹ at 68 °F (20 °C) ambient temperature; ² Switching difference 12.6 °F ± 7 °F tolerance (7 K ± 4 K)
Approvals
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The compact CS 130 high performance fan heater prevents formation of condensation and provides an evenly
distributed interior air temperature in enclosures. This fan heater is available with an optional integrated thermostat for temperature control. The CS 130 was designed as a stationary unit for panel or DIN rail mounting. For foot
mounting on the bottom of an enclosure, the CS 030 fan heater is recommended.
很抱歉,暂时无法提供与“13060.9-00”相匹配的价格&库存,您可以联系我们找货
