01115.0-00
01115.0-00
    STEGO
01115.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com COMPACT THUMBWHEEL THERMOSTAT STO 011 / STS 011 >>Adjustable thumbwheel setting >>Compact design >>Small hysteresis >>High switching capacity >>DIN rail mountable TECHNICAL DATA Convenient minimum setpoint symbol on the NC thermostat to assure enclosure temperature remains above freezing. Switching difference 7 °F (4 K) ± 5.4 °F (3 K) tolerance Sensor element thermostatic bimetal Contact type snap-action contact Service life > 100,000 cycles Max. switching capacity 15 A resistive / 2 A inductive @ AC 120 V 10 A resistive / 2 A inductive @ AC 250 V DC 30 W (DC 24-72 V) Max. inrush current AC 16 A for 10 sec. Connection 2-pole terminal, clamping torque 1 Nm max.: solid/stranded1 wire - AWG 14 max. (2.5 mm²) Housing plastic, UL 94V-0, light grey Mounting clip for 35 mm DIN rail, EN 60715 Mounting position vertical Operating / Storage temperature -49 to +176 °F (-45 to +80 °C) Operating / Storage humidity max. 95 %RH (non-condensing) Dimensions 2.76 x 1.3 x 1.65” (70 x 33 x 42 mm) Weight approx. 1.8 oz. (50 g) Protection type IP20 Approvals UL File No. E164102, VDE, GOST-R ¹ When connecting with stranded wires, wire end ferrules must be used. Important note: The contact system of the regulator is subjected to environmental influences, thus the contact resistance may change. This can lead to a voltage drop and/or self-heating of the contacts. Thermostat STO 011 NC (red) NC (blue) Heater Thermostat STS 011 e.g. Fan Thermostat STS 011 Wiring examples Enclosure heater Filter fan, cooling equipment, signal device Part No. (NC) Part No. (NO) Setting range 01115.9-00 01116.9-00 +32 to +140 °F 01115.0-00 01116.0-00 0 to +60 °C e.g. Signal Device min: 24 V; 20 mA 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The ST 011 thermostat is an SPST regulator with small hysteresis. The housing design ensures optimized air circulation around the sensor element. Thermostat NC (normally closed): Thermostat opens on temperature rise (red thumbwheel) – for regulating heaters or for switching signal devices when temperature has fallen below the minimum value. Thermostat NO (normally open): Thermostat closes on temperature rise (blue thumbwheel) – for regulating filter fans, heat exchangers, cooling devices or for switching signal devices when temperature limit has been exceeded.
01115.0-00 价格&库存
很抱歉,暂时无法提供与“01115.0-00”相匹配的价格&库存,您可以联系我们找货
  • 1+148.845691+19.33430
  • 5+130.751075+16.98390
  • 10+125.7924510+16.33980
  • 25+120.3118625+15.62790
  • 50+116.0491950+15.07420
库存:103
01115.0-00
    • 1+253.20204
    • 5+248.75533
    • 12+242.52786
    • 25+236.02962
    • 50+230.58318
    库存:56
