01880.9-40
01880.9-40
    STEGO
    STEGO - 01880.9-40 - OUT FILTER FAN, 115VAC, 12W, 3.62X3.62"
01880.9-40 数据手册
8/7/2017 | Page 1 of 2 Stego, Inc. 1395 South Marietta Parkway Building 800 Marietta, GA 30067, USA Toll-Free: (888) 783-4611 • Phone: (770) 984-0858 Fax: (770) 984-0615 Email: info@stegousa.com • Website: www.stegousa.com Part # 01880.9-40, FPO 018 Air Exhaust Fan NO flaps 11.2cfm, 115VAC, 3.62x3.62" (92x92mm) New air-flap outlet technology for high airflow Easy mounting Protection type/Environmental ratings by independent testing agencies (VDE & UL) Two optional systems for optimal airflow (FPI/FPO) Industry-common enclosure cut-out sizes (5 sizes) Single filter mat system design Filter fans are used to provide "cooling" by forced air-circulation in enclosures and cabinets containing eletrical/ electronic and other components. The interior temperature of an enclosure can be reduced by Specifications | Technical Data Specifications Operating Voltage AC 115 V, 50/60 Hz Air Volume, Free Blowing 18.8 cfm (32 m3/h) Air Volume with Exhaust Filter 11.2 cfm (19 m3/h) Current Consumption (50/60 Hz) 115 mA Power Consumption 12 W Average Noise Level (DIN EN ISO 4871) 41 dB (A) Mounting Depth 2.8 inches (72 mm) more 8/7/2017 | Page 2 of 2 Weight (approx.) 1.3 lbs. (0.6 kg) Technical Data Axial Fan, Ball Bearing service life L10 at +104 °F (+40 °C): min. 50,000 h fan body aluminum, metal impeller Connection 2 stranded wires, 11.8 inches (300 mm) long Housing, Hood, Flaps plastic UL 94V-0, light grey; UV light resistant according to UL 746C (f1) Enclosure Cut-Out 3.62 x 3.62+0.04 inches (92 x 92+1 mm) Mounting 1 Frame1 4 built-in ratchet push levers for mounting (6 ratchet stops to accommodate for wall thicknesses Gauge 9 to 19 or 1-4 mm). Additional screw mounting possible if needed. Filter Mat G3 acc. to DIN EN 779, average arrestance Aa 84 % Filter Material synthetic mesh with progressive construction, temperature resistant to +212 °F (+100 °C), self-extinguishing class F1, moisture resistant to 100 % RH, reusable Operating/Storage Temperature -40 to +158 °F (-40 to +70 °C) Operating/Storage Humidity max. 90 % RH (non-condensing) Protection Type/Protection Class IP54 / I (grounded) Environmental Rating UL/NEMA UL TYPE 12 / NEMA 12 Approvals VDE, UL File No. E234324, EAC Note other voltages on request Drilling hole markings for screw mounting are indicated on mounting frame.
01880.9-40
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种高速光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,包括输入、输出和电源引脚。
4. 参数特性:工作电压范围为3V-15V,隔离电压为2500Vrms。
5. 功能详解:EL817通过光电效应实现电信号隔离,适用于高速数字信号传输。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
01880.9-40 价格&库存
很抱歉,暂时无法提供与“01880.9-40”相匹配的价格&库存,您可以联系我们找货
