14000.0-00
14000.0-00
    STEGO
14000.0-00 数据手册
Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com www.stegousa.com PTC HEATER HG 140 | 15 - 150 W >>Compact size >>Wide voltage range >>Heating power adjusts to ambient temperature >>Cage clamp connectors for quick & easy wiring >>DIN rail mountable TECHNICAL DATA 1 2 Operating voltage1 AC/DC 120-240 V (min. 110 V, max. 265 V) Heating element PTC resistor - temperature limiting Heater body extruded aluminum profile, anodized Connection 3 cage clamps for solid wire AWG 20-14 (0.5-2.5 mm²), and stranded wire (with wire end ferrule) - AWG 20-16 (0.5-1.5 mm²) Connection casing plastic, UL 94V-0, black Mounting clip for 35 mm DIN rail, EN 60715 Mounting position vertical Operating / Storage temperature -49 to +158 °F (-45 to +70 °C) Operating / Storage humidity max. 90 %RH (non-condensing) Protection class / Protection type I (grounded) / IP20 Approvals UL File No. E150057, VDE, GOST-R Note other voltages available upon request Operating high voltage heaters below AC/DC 140 V reduces heating performance by approx. 10%. Part No. Heating capacity2 Max. current (inrush) Length (L on dim. dwg.) Weight (approx.) 14000.0-00 15 W 1.5 A 2.56” (65 mm) 7.6 oz. (215 g) 14001.0-00 30 W 3.0 A 2.56” (65 mm) 7.6 oz. (215 g) 14003.0-00 45 W 3.5 A 2.56” (65 mm) 7.6 oz. (215 g) 14005.0-00 60 W 2.5 A 5.5” (140 mm) 14.1 oz. (400 g) 14006.0-00 75 W 4.0 A 5.5” (140 mm) 14.3 oz. (405 g) 14007.0-00 100 W 4.5 A 5.5” (140 mm) 14.3 oz. (405 g) 14008.0-00 150 W 9.0 A 8.66” (220 mm) 21.3 oz. (600 g) at 68 °F (20 °C) ambient temperature 08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. These heaters are used in enclosures where damage from condensation must be prevented, or where the  temperature must be maintained above a minimum  value. The aluminum profile heater body design has a chimney effect to distribute heat evenly. The cage clamp connectors save time and simplify installation.
14000.0-00 价格&库存
很抱歉,暂时无法提供与“14000.0-00”相匹配的价格&库存,您可以联系我们找货
