Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
MECHANICAL HYGROSTAT
MFR 012
>>Efficient condensation control
>>Adjustable relative humidity range
>>High switching capacity
>>DIN rail mountable
The MFR 012 electromechanical hygrostat is designed to control the relative humidity inside enclosures. When
connected to an enclosure heater (dehumidifier), it will energize the heater at the humidity set point in order
to raise the dew point. This helps prevent damage and malfunction of electronic components caused by condensation and corrosion.¹ The MFR 012 can also be used to control cooling fans, warning lights or other devices.
TECHNICAL DATA
Switching difference
4 %RH (± 3 % tolerance) - at 50 %RH
Permissible air velocity
50 ft/sec (15 m/s)
Contact type
SPDT / change-over contact
Service life
> 50,000 cycles
Min. Switching capacity
100 mA @ AC/DC 20 V
Max. Switching capacity
5 A resistive @ AC 250 V
DC 20 W
Connection
3-pole terminal, clamping torque 0.5 Nm max.:
solid wire - AWG 14 max. (2.5 mm²)
stranded wire1 - AWG 16 max. (1.5 mm²)
Housing
plastic, UL 94V-0, light grey
Mounting
clip for 35 mm DIN rail, EN 60715
Mounting position
vertical
Operating / Storage temperature
+32 to +140 °F (0 to +60 °C) / -40 to +140 °F (-40 to +60 °C)
Operating / Storage humidity
max. 95 %RH (non-condensing)
Dimensions
2.64 x 1.97 x 1.5” (67 x 50 x 38 mm)
Weight
approx. 2 oz. (60 g)
Protection type
IP20
Approvals
UL File No. E164102, GOST-R
¹ When connecting with stranded wires, wire end ferrules must be used.
Heater
Hygrostat
MFR 012
Hygrostat
MFR 012
Enclosure heater
Filter fan, cooling equipment, signal device
Wiring examples
Part. No.
Setting range
01220.0-00
35 to 95 %RH
e.g. Filter Fan
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
¹ The critical relative humidity level for most components is 65%. Above 65% RH, condensation can form and cause malfunctions
of electronic equipment. Long term, this can lead to corrosion and permanent damage of electronic components and systems.
很抱歉,暂时无法提供与“01220.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+756.349421+94.51320
- 5+711.858275+88.95360
- 10+667.4575610+83.40530
